AGV Air-Tech - Visor Changing
veeeffarr
PostPosted: 18:03 - 09 Aug 2005    Post subject: AGV Air-Tech - Visor Changing Reply with quote
Hi guys,
Anyone know how to change an AGV Air-Tech Visor? (Or remove it)
Also, is it safe to clean the visor with generic "screen and keyboard cleaning wipes"?
If not, I've just made a booboo Smile
BigChris
PostPosted: 22:06 - 09 Aug 2005    Post subject: Reply with quote
Hopefully it'll have the same fitting as the GP Pro.
Open the visor fully, and on one of the sides (I think left) there will be a little lever sticking out from the bottom of the visor, push it upwards, and then rotate - GENTLY - the visor - on that side only - upwards, it should click out of place. Then work the right hand side downwards as if closing the visor, and it should then pop out.
When fitting it back, make damned sure that you've got the locator studs sitting in their 'slots' before you ham fist it all back together.
(A replacement is about £40, just so's you know).
Screen wipes is not a good idea. Barely ok if you've done it once on yer clear plastic, but for gods sake not on their iridium, its thin enough as it is without solvents melting it off!
veeeffarr
PostPosted: 12:56 - 10 Aug 2005    Post subject: Reply with quote
Fraid there's no lever Sad
The last post was made 20 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 35.72 Kb
