Tapping sound as started whilst riding?
darren01274
PostPosted: 22:52 - 03 Aug 2005    Post subject: Tapping sound as started whilst riding? Reply with quote
Hi all a tapping sound as started whilst riding my bike haven't heard it before what could it be
Irezumi aka Reuben
Carrot Top
PostPosted: 00:17 - 04 Aug 2005    Post subject: Reply with quote
What's the bike and where is the sound coming from. Try to be as accurate as possible. Also is it whilst moving or when still. When warming up only or all the time. Or in a certain area of the rev range?
Dont forget the year/model designation of the bike as this will make things easier to work out.
Do this and then people will answer.
Pictorgraphicalfantastical
darren01274
PostPosted: 00:47 - 04 Aug 2005    Post subject: Reply with quote
its a year old and its whilst riding it no tapping sound when reving the engine when still
mchaggis
PostPosted: 00:57 - 04 Aug 2005    Post subject: Reply with quote
Check the condition of your chain and sprockets. What bike is it? It could be valve clearances, but they don't normally fall out of adjustment that quickly. It could easily be a loose nut or bolt somewhere, not neccesarily from the engine at all. Is the engine running hot and noisy - are you running low on oil? Does it happen all the time (with or without the clutch pulled in?), or only under a decent amount of acceleration? Is there any power loss?
I must not be a troll...
Mmmm, Guinness
darren01274
PostPosted: 02:43 - 04 Aug 2005    Post subject: Reply with quote
Yes it happens all the time if i pull the cluth in whilst out riding the tapping noise stops i've checked the oil and even done an oil change to see if that would cure it, the bike doesnt seem to have lost any power, the bike is a suzuki rv125
rs-craig
PostPosted: 14:18 - 04 Aug 2005    Post subject: Reply with quote
we herd a tappin on our honda c90 that we used 2 thrape ova the local park , we found out that the more we rode it the worse it got - sound familiar ?? , erm we took the head off only 2 find tiny pieces of piston hand broken off and were making the taping noise wen we screemed it , it cud b that ????? Confused
jimster
PostPosted: 00:13 - 10 Aug 2005    Post subject: Re: Tapping sound as started whilst riding? Reply with quote
A tapping sound means your engine has become stale!
To solve this, you need to refresh your engine. Mix a dash of lemon juice and some fresh ginger into a 50/50 blend of vinegar and petrol, and put it in the petrol tank, then turn the engine on, add some washing up liquid and rev the engine hard.
When you can smell lemony/ginger tones coming from the exhaust, the engine should be clean and fresh, and the only audible tapping sounds should be coming from your rhythmically-charged feet as you listen to the blues while cruisin' the freeways on a sultry summer afternoon.
Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped
Josh|RD125LC
PostPosted: 01:29 - 10 Aug 2005    Post subject: Reply with quote
Eh?
Anyway, check your chain, see if its slack. My chain was ultra slack, but before I checked, I could hear tapping noises as well. Turned out to be the chain so loose it was tapping on the side of the swing arm.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
THCi
PostPosted: 03:53 - 10 Aug 2005    Post subject: Re: Tapping sound as started whilst riding? Reply with quote
Please tell me you are joking. Shocked
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
darren01274
PostPosted: 13:19 - 10 Aug 2005    Post subject: Reply with quote
Hi erm dont think ill try the vinegar and ginger combined with washing up liquid in the engine checked the chain and its fine thanks for the advice though Cool Smile
jimster
PostPosted: 19:16 - 10 Aug 2005    Post subject: Re: Tapping sound as started whilst riding? Reply with quote
Don't knock it until you've tried it! Chequered Flag
Then you can knock it.
The last post was made 20 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 69.35 Kb
