What's the extent of your bike mechanical knowledge?
Gazdaman
I did a trackday!!!
PostPosted: 12:46 - 10 Aug 2005    Post subject: What's the extent of your bike mechanical knowledge? Reply with quote
I made this thread to see what kind of in depth jobs some of you have done on your machines.
Myself I've swapped heads on my XJ600, obviously had to do the timing in there.
I've had swingarm out on the TZR250, I've had the engine out of both bikes.
I've changed fork seals. I'm sure I could check valve clearances, but I didn't want to scare myself by trying on the XJ.
I'm going to be impressed with those people who've changed pistons/rings.
I've not done any kinds of bearings either, when the wheel bearings needed doing on the rear wheel on the XJ we bought a new wheel with tyre for a tenner.
Gaz
PostPosted: 12:53 - 10 Aug 2005    Post subject: Reply with quote
Do a reasonable amount. Sometimes chicken out of nasty jobs (eg, drilling out sheared bolt).
freestyler_onli
PostPosted: 12:55 - 10 Aug 2005    Post subject: Reply with quote
Yeah i clean mine sometimes Shocked
Thats about all i can do. Evil or Very Mad
Vespa
feef
Energiser Bunny
PostPosted: 12:57 - 10 Aug 2005    Post subject: Reply with quote
rebuilt the engine on the GPZ,
replaced fork seals on same.
so far have stripped and serviced brake calipers front and rear on the 'ace, and have replaced the rear disk.
Replaced rear wheel bearings.
fitted aftermarket grabrail.
will be stripping the water pump to check that's okay, as I suspect a possible coolant flow problem (only noticed it on a trackday, when the bike got hotter than normal)
Have a spare engine I'm about to split and fit a YZF750 gearbox in, maybe fettle it a bit too.
(reminds me.. Must PM that guy about the 'box)
a
edit:
Forgot to add...
fitted big-bore kit to an NSR 125, made a footpeg for it out of alu alloy bar and replaced/repaired almost all body work after I got it for £90 as an insurance write of after the owner siezed the engine on the motorway.
:edit
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Irezumi aka Reuben
Carrot Top
PostPosted: 13:00 - 10 Aug 2005    Post subject: Reply with quote
Usual basic maintanence. Am going to do a piston/ring/crank seal/gearbox selector fork overhaul in the coming weeks. It's an old 2-stroke so should be simple. Chances are it wont be though.
Changing fork seals, bearings etc is normally done easily enough. Head bearings and fork seals are a bastard as you have to take the front end of, and you will always ball's up getting the cabling sorted for the headlight/throttle and have to do it again! Rolling Eyes
Pictorgraphicalfantastical
Wave2k
G's Stalker
i usually get my dad to do scary jobs, so if it goes wrong i can blame him and he pays Laughing
Ducati 1299 Panigale
2009 Corvette C6 z51
Aikman666
PostPosted: 13:13 - 10 Aug 2005    Post subject: Reply with quote
Completely rebuilt and resprayed a 2-stroke BSA last year. Gave the engine a nice clean and a top end rebuild. Done some machining on the parts here and there. Had to redo timing, and edit some of the carburation settings. Had to redo the electrics on the bike too (was helped at that part though). All that at the age of 14 Laughing
Will work for petrol
My Design Blog
map
Mr Calendar
PostPosted: 13:18 - 10 Aug 2005    Post subject: Reply with quote
Vespa wrote:
...Can't find a scooter maintenance course, some motorcycle courses though...
Motorcycle and scooter courses should be the same. Same basic skills required. The City & Guilds course I did you had to be able to work on either machinery. There's something quite beautiful in the simple design of a scooter belt drive Very Happy.
I did come across this link https://www.courseinfo.co.uk/courses/short/course17076.cfm if it's of any use.
Sign up for a course and go for it Thumbs Up
...and if my course is anything to go by the guys will be falling over themselves to help any female that attends Wink
Keen
PostPosted: 13:19 - 10 Aug 2005    Post subject: Reply with quote
done oil changes, installed new throttle cable, stripped a carb once.... not much really. The idea of doing anything complex scares me, I'd be so worried about messing up.
My lack of mechanical knowledge annoys me. I keep meaning to learn more but I'm not sure how to go about it. Anyone recommend a good book- 'motorcycle mechanics for dummies' maybe? Razz
Zoffo
PostPosted: 13:21 - 10 Aug 2005    Post subject: Reply with quote
I'm willing to have a go at most things but the only thing I shy away from is electrickry Shifty
https://hyperbikes.forumsplace.com/
Josh|RD125LC
PostPosted: 13:27 - 10 Aug 2005    Post subject: Reply with quote
Stripped the RD totally to bare frame. Not hard. I have taken carbs apart and cleaned them out before, not hard either. Fitted a replacement piston and rings. Now thats tricky. Got my dad to rebuild the RD engine though. Didn't fancy doing it as I want it to be alright. When I buy another project, I'll make sure I do it all myself next time.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
Barry_M2
Anything and everything.
And if there is anything I dont know how to do, I'll learn.
You just need to have confidence in yourself and not be afraid to give it a try.
When I was 16 my mechanical knowledge was ZERO! I started off doing basic maintainence on my bikes, then cars, now I'm more than competant stripping and re-building an engine. Next on my list of things to learn is head modifying and gas flowing etc..
Oh, never taken a gearbox apart either!
Smile
0ddball
PostPosted: 14:01 - 10 Aug 2005    Post subject: Reply with quote
I only started riding recently so i've not had much to fix. Just service stuff, cleaning the carb out and putting a new clutch in so far. But i've done plenty on cars from building high spec engines to complete bare shell rebuilds so i recon i'd have a go at fixing most things on a bike.
spitfire
PostPosted: 14:11 - 10 Aug 2005    Post subject: Reply with quote
pretty good, only a warranty and lack of workshop facilities stop me doing little more than tightening the chain at the moment!
biggerjohn
PostPosted: 14:14 - 10 Aug 2005    Post subject: Reply with quote
If I had a project bike I would be happy to do just about any thing to it in the knowledge if I fuck it up or can’t work out how to do something there and then I can always come back to it the next day and sort it out. But when it comes to my bike I have to use every day for commuting I don’t mind spending a few quid on an experienced professional to do the job for me.
It like my job it has taken years of day to day experience and training to become as proficient as I am but that’s not to say a talented novice couldn’t do the same given enough time and the chance to fuck it up a few times before getting it right and even then they may not notice the very minor things I would that could potentially cause a major fuckup.
I just can’t risk the fuck ups with the bike I need to get to work.
Dom_
Points Mean Prizes
PostPosted: 14:20 - 10 Aug 2005    Post subject: Reply with quote
Just basic stuff like top end rebuilds on 2 strokes, stripped/cleaned carb, top end bearings, wheel bearings, stripped the bike down to it's minimum.
It's all pretty easy, just like a 3d jigsaw. Wouldn't mind learning about 4 strokes though, will do when i get one. Mr. Green
Vespa
PostPosted: 15:27 - 10 Aug 2005    Post subject: Reply with quote
map
Mr Calendar
PostPosted: 15:35 - 10 Aug 2005    Post subject: Reply with quote
Vespa wrote:
How did you know I'd need Fulham & Hammersmith???...I haven't seen any motorbike maintenance courses anywhere nearer...
...because I'm good like that Angelic Whistle
Vespa wrote:
...I was worried about the course concentrating on maintaining and repairing things I don't have...
...if it's a basic course then it'll cover everything you need to service your own bike/scooter. In fact if they don't have much kit to demonstrate stuff on you might be encouraged to take yours along for the practical work. That has to be a good thing Thumbs Up
Vespa wrote:
...The only problem is that there will be some hairy bikers there! Laughing
...don't worry, I'm sure some shave and I heard a rumour some even bathe, although not if it's a bit too much like swimming Very Happy
Vespa
PostPosted: 15:44 - 10 Aug 2005    Post subject: Reply with quote
DynaMight
PostPosted: 16:12 - 10 Aug 2005    Post subject: Reply with quote
I started off knowing nothing at all, Changing a sparkplug would be out of my league.
I'll do most things now (tools permitting) have never totally striped a bike, rebuilt a engine or anything drastic like that. If it aint broke dont fix it!
map
Mr Calendar
PostPosted: 16:24 - 10 Aug 2005    Post subject: Reply with quote
Vespa wrote:
map wrote:
...you might be encouraged to take yours along for the practical work. That has to be a good thing Thumbs Up
My kit?...
...through work on your own and other student's bikes....
Just to clarify, I did mean take your own bike/scooter and do the practical work on that, which is what the course says anyhow. They'll provide tools, you'll just have to supply any bike bits, oil, filters, brake pads, etc. (as you'd expect to) Thumbs Up
Vespa wrote:
...10 weeks at 2.5h a week for £86. Thumbs Up
I take it that's a yes and you're signing up Very Happy Thumbs Up
Vespa
PostPosted: 16:29 - 10 Aug 2005    Post subject: Reply with quote
map
Mr Calendar
PostPosted: 16:37 - 10 Aug 2005    Post subject: Reply with quote
Vespa wrote:
...my right hand isn't very strong, so a bit worried about not being able to tighten any nuts and bolts. I can just see myself riding along, and being overtaken by my rear wheel! Laughing...
That's what ratchet spanners and torque wrenches are there to stop. Very Happy Laughing
Doubt you'll have any problems, in fact you might find the fiddly bits a bit easy (women, for some reason, tend to).
Best of luck, post a thread when you're done and let us know how it went Thumbs Up
Shaun
Likes 'em bent
PostPosted: 17:09 - 10 Aug 2005    Post subject: Reply with quote
I'm pretty competent and willing to have a poke around most things, recently dropped the engine out of the ZXR, wouldn't work after but that was due to my lack of knowedge when it comes to electrics, its all good now.
The last post was made 21 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 135.87 Kb
