Clutch slipping ?
dransy
PostPosted: 13:03 - 12 Aug 2005    Post subject: Clutch slipping ? Reply with quote
Hi what exactly is this Confused if i sound dumb by asking well , yes i am ha and dont say its when you slip the clutch because i still dont know what that means Razz
What exactly do you do when you slip the clutch and what does it do?
Marc
Craggles
PostPosted: 13:27 - 12 Aug 2005    Post subject: Reply with quote
I expect you do slip the clutch without realising it.
It's where you're holding the clutch around biting point, and so the two plates are slipping against each other - so only part of the power from the engine is being transmitted to the gear box.
Every time you pull off you slip the clutch slightly... and when you're travelling slow, doing U-turns etc you are likley to be slipping the clutch.
HTH
Craig
If this signature is blue, you're riding too fast
Dom_
Points Mean Prizes
PostPosted: 14:31 - 12 Aug 2005    Post subject: Reply with quote
If you ever watch 2 strokes racing, sometimes when coming out of the corners you will hear the revs go super high then drop back down a bit, they are just pulling the clutch in slightly so it is slipping. This allows the engine to get up to peak power rather than bogging down at low revs.
lightfoot256
PostPosted: 14:51 - 12 Aug 2005    Post subject: Reply with quote
I do this a lot, after slowing down around a corner, and coming back out of it again, i tend to give it too many revs while the clutch is still slipping and then all of a sudden it catches grip and im away... kinda scary... prolly should let the clucth out earlier...
Dom_
Points Mean Prizes
PostPosted: 14:57 - 12 Aug 2005    Post subject: Reply with quote
You go around the corner with the clutch in?!!? Or slipping?!?!
You should select the correct gear before entering the corner, then accelerate throught the corner. Smile
lightfoot256
PostPosted: 15:02 - 12 Aug 2005    Post subject: Reply with quote
Uhmm... prolly not so much on corners but junctions where im waiting to go. Clutch in while i wait, then accelerate while letting clucth out, slips to hell.
Naw, i'd never go round a corner with the clucth in or slipping (not on purpose anyways)...
Walloper
PostPosted: 15:17 - 12 Aug 2005    Post subject: Reply with quote
Doesn't do it any favours mechanicaly to slip the clutch either as it can be too much of a good thing etc.
The last post was made 21 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 52.55 Kb
