mbk nitro/ yamaha aerox 50cc not starting after rebuild....
davethenorman
PostPosted: 22:05 - 13 Aug 2005    Post subject: mbk nitro/ yamaha aerox 50cc not starting after rebuild.... Reply with quote
fitted new crank piston and barrell but now will not start.
I have a spark, lots of fuel in the carb, but the plug seems dry, and no sign of life.
Does any one know if the crank has to be alined with the maneto/ ignition in any way, as I think that the spark is at the wrong place in the stroke.
Any ideas?
Thanks
Dave The Norman
edd
PostPosted: 01:30 - 14 Aug 2005    Post subject: Reply with quote
do you have compression?
Bluespark Automotive - Diesel Tuning for Performance and Economy
davethenorman
PostPosted: 12:58 - 14 Aug 2005    Post subject: Reply with quote
I have done a compression test, and only get about 45 pounds of compression.
Is this right for a small 2 stroke engine, as I have only worked on cars before which needed 120lbs plus.
We still have a spark, but not sure if petrol is getting to the plug, as it seems to come out dry.
Any ideas as to why it will not start?
Thanks for your help.
Dave
Dave The Norman
J.K.R
PostPosted: 22:58 - 14 Aug 2005    Post subject: Reply with quote
Could it be that you have a different crank (eg the woodruff hole at a different point?)
Id check the carb > cylinder/case rubber as it may be perished, and is the reed valves and cage good?
www.oldskoolsuzuki.info
Kye
PostPosted: 23:07 - 14 Aug 2005    Post subject: Reply with quote
Replaced the crank seals properly?
Ducati 600SS
Vespa PX125
The last post was made 20 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.75 - MySQL Queries: 13 - Page Size: 42.77 Kb
