Braided Brake lines 'budget ?'
swaffs
PostPosted: 12:17 - 16 Aug 2005    Post subject: Braided Brake lines 'budget ?' Reply with quote
Korn's post about brake cleaning, and my need to top up brake fluid, has possibly inspired me to attack mine.
I have seen these braided hoses on ebay:
https://cgi.ebay.co.uk/Stainless-Braided-Brake-Lines-GOODRIDGE-The-Best_W0QQitemZ7992135644QQcategoryZ9946QQcmdZViewItem
Here's the downside:
https://www.wezmoto.com/assets/images/zinc_end.jpg
This kit comes with ZINC PLATED FITTINGS instead of stainless steel.
Any used or have any thoughts on this?
I don't want to spend £70+ on hoses but also would like to replace the current rubber ones if I'm going to be doing the rest of the work on my brakes anyway.
Swaffs
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
craigs23
Mr Muscle
PostPosted: 12:37 - 16 Aug 2005    Post subject: Reply with quote
I've got the very same on my bike - apparently Zinc is fine, it's the alloy fastenings that are suspect.
Haven't had any problems in 8000miles yet, hope it stays that way.
Danny
Ask Me About Stoppie School
PostPosted: 12:50 - 16 Aug 2005    Post subject: Reply with quote
I have Hel Braided Hoses on my bike, I think they came to around £40 with the discount. They actually make them to order for you. Very Happy
Give Simon at HEL Performance a ring on 01392
811601. Tell him Stuart at TFR Racing told you to call, you should get a 25% discount.
PostPosted: 13:54 - 16 Aug 2005    Post subject: Reply with quote
Nothing wrong with zinc plated fittings. Work well, just will look a bit tatty in a few years but will still be safe.
However, do you really need new hoses? I am not keen on the reduced feel you get with braided steel hoses, and half the time the spongyness people blame on the hoses is down to the brakes needing bleeding and the calipers needing a strip down and rebuild.
swaffs
PostPosted: 14:00 - 16 Aug 2005    Post subject: Reply with quote
I don't feel that the standard hoses I currently have are bad at all.
they do occasionaly feel sticky when pulling the lever, but I'm sure cleaning the callipers is giong to sort that.
My thoughts were just that while I was pulling everything to bits, it might be a good time to replace the 5 year old 10k miles rubber hoses, as I'm sure they don't last forever?
BCF vinyl stickers
map
Mr Calendar
PostPosted: 14:03 - 16 Aug 2005    Post subject: Reply with quote
Kickstart wrote:
...do you really need new hoses?...
I'd say worth looking at if the original lines are certainly 3-5 years old (depends on the manufacturer & bike). Maybe sooner if taken off and left to hang, so stretched. When replacing lines you'd generally tidy up the pots and pads so overall difficult to tell what's made the difference. However, with the mods combined the effect can be surprising. Very Happy
PostPosted: 14:15 - 16 Aug 2005    Post subject: Reply with quote
If you mean what I think you do (a sort of non smooth action to the lever) then pull the lever off and grease the pivot point, and also where the lever pushes on the piston in the master cylinder.
They do not last for ever, but they last a lot longer than some people think. The Bandit hoses are still original and that is getting on for 9 years old with over 50000 miles on the clocks. Probably could do with some cleaning up but the action is still quite nice (for me) and I have not got a hope in hell of getting the lever back to the bars. The FZR brake lines are also original and that is J reg with 42K on the clocks. They did get a bit spongy but stripping and cleaning the o/s caliper (which had started to stick) made them far better (really should do the other caliper when I have a chance, but by stripping I mean taking the whole caliper to pieces).
Some people prefer the feel of braided hoses, some don't. That is very much personal preference.
PostPosted: 14:27 - 16 Aug 2005    Post subject: Reply with quote
From what I recall of the service manual on my kawasaki, you are supposed to replace rubber brake lines every 4 years.
Oh yeah, £70 seems a trifle pricey to me, you tried busters online shop? I was £10 for a single braided steel line.
PostPosted: 14:46 - 16 Aug 2005    Post subject: Reply with quote
Go for twin front lines and leave the back - also, though you shouldn't, you can probably reuse washers etc, if they don't come free.
PostPosted: 15:03 - 16 Aug 2005    Post subject: Reply with quote
Yep, and coolant hoses on newer bikes Laughing .
Plus banjo bolts and washers. Those ones on Ebay that Swaffs is thinking about are £40. Personally I would be tempted to pay the extra for a plastic shrink wrap that these hoses come with to try and help prevent this (not covered by the lifetime warrenty).
mr jamez
PostPosted: 15:04 - 16 Aug 2005    Post subject: Reply with quote
Yeah I got mine from busters as well for a tenner, they come supplied with new copper washers.
swaffs
PostPosted: 15:50 - 16 Aug 2005    Post subject: Reply with quote
and the banjo bolts etc.?
These Ebay ones come as a full set
https://www.wezmoto.com/assets/images/zinc_unboxed.jpg
For £39.95.
Is that purely for cost purposes or ir the back fiddly to replace?
BCF vinyl stickers
PostPosted: 21:11 - 16 Aug 2005    Post subject: Reply with quote
£1.50 each.
Just most people don't use the back brake much and don't need it to be all that good.
Robby
Dirty Old Man
PostPosted: 21:19 - 16 Aug 2005    Post subject: Reply with quote
I'd just stick with the standard lines, braided lines are nothing that great in reality. I don't like the feel of them, you don't get such a reassuring squeeze.
Another case of, if they were really that great, I'm sure they'd be fitted as standard kit on at least some bikes.
As for changing them at 5 years, I doubt it would need doing. One of my old cars had rubber brake lines that were at least 10 years old, and possibly 20 (original). They still worked.
Black Knight
PostPosted: 21:25 - 16 Aug 2005    Post subject: Reply with quote
I met Mr Wez Moto a few weeks back. He posts on another forum I use. I bought some of his products a few months prior to actually meeting him and can wholeheartedly recommend them.
I fitted those very same hoses to my FZR and they are the business.
He's a lovely helpful chap and will go out of his way to assist you. Bit crazy on two weels though, he was running his 300 miler R1 in by seeing how much he could get in first, 98mph IIRC! Laughing
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
PostPosted: 21:40 - 16 Aug 2005    Post subject: Reply with quote
I have to disagree, I reckon thay make the brakes more responsive. I suppose if your brakes were razor-sharp, it would make the difference between "Braking really hard" and "Front wheel locked" smaller.
Just like they fit socket head cap screws instead of cross-heads to hold the crankcase covers on, stainless header pipes instead of mild steel and caged roller bearings instead of loose balls on the headstock?
MZ do.
swaffs
PostPosted: 21:59 - 16 Aug 2005    Post subject: Reply with quote
I've decided just to keep things as they are, after cleaning the calipers (well one at the moment as per Korns guide.) it feels better already, will do the other one tomorrow and also look at the lever bits.
Maybe will address the hoses next time.
Thanks for all your responses Thumbs Up
BCF vinyl stickers
PostPosted: 22:23 - 16 Aug 2005    Post subject: Reply with quote
They are fitted to some bikes as standard. Early Aprilia AF1 had them, Aprilia AF1 Futura, the Bimota has them and I think quite a few Triumphs use them.
I prefer some travel to the brake lever. With braided hoses you can land up with virtually not movement unless the master cylinder bore is quite small compared to the area of the brake caliper pistons.
Villers
PostPosted: 23:05 - 16 Aug 2005    Post subject: Reply with quote
Yo,
I got a set from an Ebay seller called 'waddymc', he workls for Edge MX and makes HEL lines specifically for any bike. it cost me £49 delivered (buy it now) for front and back with fittings etc for a CBR600. These ones have the stainless fittings I think (the ones that dont corrode).
Good luck Wink
Big Pete
PostPosted: 16:24 - 17 Aug 2005    Post subject: Reply with quote
get the compression style fittings and make the lines up to suit your bike, use two lines as mentioned earlier, its cheaper and easier to bleed. Fit a hydraulic switch rather than the nasty plastic one. Re-use the bolts that were in the original hoses. Use copper slip on all the threads (dont forget the bleed screws). Last but not least throw away the copper washers and use 1/8th BSP Doughty washers, they will seal with a 1/4 turn or so after being nipped up , so less risk of stripping caliper threads trying to get a decent seal, and they can be re-used. If you really want to use copper washers heat them to glowing red in a gas cooker or blow torch and let them cool down slowly so they are annealled before you use them.
Trust me, I`m an engineer
GarageOfPower.co.uk
craigs23
Mr Muscle
PostPosted: 16:29 - 17 Aug 2005    Post subject: Reply with quote
I know what you mean, I compensated more lever movement by changing my standard callipers to those off an SP2 to give more feel (same fitment, bigger calliper pistons).
Hope the finish lasts on my hoses though Neutral
PostPosted: 17:05 - 17 Aug 2005    Post subject: Reply with quote
I always just cooled them in water so they don't go quite so oxidised then wash them off with some vinegar to make them shiny again. Didn't think copper minded a fairly rapid cooling?
Big Pete
PostPosted: 17:24 - 17 Aug 2005    Post subject: Reply with quote
IIRC it depends on how pure the copper is, but for the sake of 30 seconds I let them air cool.
GarageOfPower.co.uk
mchaggis
PostPosted: 17:32 - 17 Aug 2005    Post subject: Reply with quote
How similar is copper tempering and annealing/ stress relieving to that for steel? It seems to be a bit tricky to find information on other metals for some reason. It could just be me being too lazy to dig up my materials lecture notes of course. Smile
I must not be a troll...
Mmmm, Guinness
Big Pete
PostPosted: 13:27 - 18 Aug 2005    Post subject: Reply with quote
compared to steel, copper is a piece of piss, heat it up (good red), cool it down, as long as its hot all the way through, job done.
GarageOfPower.co.uk
The last post was made 21 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 140.88 Kb
