Preventative maintenance questions
Danny
Ask Me About Stoppie School
PostPosted: 11:41 - 16 Aug 2005    Post subject: Preventative maintenance questions Reply with quote
I’ll be doing an engine swap on my Thundercat soon and wanted to know if there was anything else I should do while I’ve got the engine out?
PostPosted: 13:57 - 16 Aug 2005    Post subject: Reply with quote
Clean all the bits of the frame you cannot normally get at. If an original mild steel exhaust then clean it and paint it. Maybe strip and grease the rear suspension linkage while the engine is out (so the bike is lighter and easier to hold up). Maybe consider doing the valve clearances on the new engine before fitting it (while you have it there is far more space) and replace the plugs.
Danny
PostPosted: 14:22 - 16 Aug 2005    Post subject: Reply with quote
Any idea how hard/time consuming greasing the rear suspension linkage is?
PostPosted: 14:56 - 16 Aug 2005    Post subject: Reply with quote
Time consuming but not hard. Tends to get messy as you are playing with grease and the dirty bits of the suspension that hang around in line with the wheels.
map
Mr Calendar
PostPosted: 17:40 - 16 Aug 2005    Post subject: Reply with quote
Not directly connected to the engine being out but as well as suspension maybe worth checking the swingarm is all ok.
PostPosted: 15:02 - 17 Aug 2005    Post subject: Reply with quote
Just thought of something else. The studs for the exhaust manifolds often corrode with age. If they look dodgy then replace them before slotting the engine in. This way if one shears off you can take the engine in to someone who has the skills and tools to remove it.
The last post was made 21 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 49.4 Kb
