Engine Overhaul Parts or New Engine
YellowCat
PostPosted: 22:57 - 16 Aug 2005    Post subject: Engine Overhaul Parts or New Engine Reply with quote
The ball bearing on the transmission exit shaft on my engine is destructed Sad
To replace it I have to open up the entire engine and probably do at least a partial overhaul. This is a '97 Yamaha YZF600R and the engine has 105K km on it (66K miles).
Can anyone recommend a good, not expensive, place to purchase overhaul parts - gasket kits, piston rings, bearings, etc.? Aftermarket part would do just fine.
Also, I am considering the option to buy a complete used engine. Can anyone recommend a reliable place for buying an engine?
Thanks.
ZRX61
Victor Meldrew
PostPosted: 03:18 - 17 Aug 2005    Post subject: Reply with quote
Piston rings?? why are you even taking the top end apart to change a bearing in the gearbox??????????
YellowCat
PostPosted: 07:17 - 17 Aug 2005    Post subject: Reply with quote
Because I have to Sad. two of the cranckcase bolts are located UNDER the cylinders. There's no way to get the crankcase open without removing the cylinder block first
Guest
PostPosted: 07:20 - 17 Aug 2005    Post subject: Reply with quote
What our friend is implying is that on a lot of engines you can split the crankcases and access the gear shafts without disturbing the top end. I don't know if this is the case with your engine, you'd need to carefully study a workshop manual.
You need to remove everything from the sides of the cases, including the clutch drum, as there is sometimes a plate or bearing retainer behind the clutch that is bolted across both case halves. This is easier to do if the engine is still in the frame.
Then remove the engine unit, turn it upside down and remove all the case bolts and the bottom half should come away, leaving the crank and gearshafts in place in the top half.
Again, it's a case of RTFM ro make sure you've got everything off (including any hidden case bolts) before trying to part the cases.
At 60k miles, if the engine hasn't had a hard life and has had regular oil changes, I wouldn't expect any serious problems in the top end so you mayas well leave it be.
Guest
PostPosted: 07:21 - 17 Aug 2005    Post subject: Reply with quote
Ah, simultaneous post Embarassed and you obviously have RTFM Thumbs Up
Danny
Ask Me About Stoppie School
PostPosted: 08:49 - 17 Aug 2005    Post subject: Reply with quote
I've just bought a 2nd hand engine from a breakers in Dorset: 01202489680. I haven’t had it delivered yet so I can't say how reliable they are. But I can say I paid £375 where all other breakers wanted £500+ for a similar condition engine.
sickpup
Old Timer
PostPosted: 23:32 - 17 Aug 2005    Post subject: Reply with quote
No they wanted cash for an engine they knew nothing about.
The last post was made 21 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 50.59 Kb
