| killa |
 killa Won't Shut Up
 Posted: 11:41 - 17 Aug 2005 Post subject: Shit bag |
I have mentioned this before but I need some more opinions as to find the fault is going to cost me and I don’t want to go in blind.
The VFR is running sweet, or very nearly, basically the bike is quick at high speeds, revs nicely up around 7Krpm and up. But the problem I am getting is when you come to corners that need you to go through gears etc at low RPM. The bike, especially when low’ish on fuel needs a good kick up the arse to get her past 4.5KRPM to about 5.5KRPM.
I am experiencing a burbling effect at lows speeds and rev, so you can imagine from the lights a quick launch requires a lot of stick which in turn is no good for my clutch. I have a large can on the back which I am reluctant to get rid of because of the sound it makes but I have been told this could be leading to the problem due to low pressure.
The problem is hard to nail because this could be anything from the Air intake, fuel and carbs, oh and the can. It does change when at different running temperatures.
Any thoughts?
Thanks
Killa ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:20 - 17 Aug 2005 Post subject: |
Does sound like a possible issue with the carbs needing setting up for the can you have. At a guess at that point in the rev range the can is causing it to run lean (or possibly just working rather too badly at half peak power, ramming exhaust gases back into the engine).
Stick it on a dyno with an exhaust gas analyser and see what it has done.
You might be able to get away with shimming the standard needles up to richen the mixture. You might need a dynojet kit with some reprofiled needles. You need someone with good knowledge of setting bikes up.
| killa |
 killa Won't Shut Up
 Posted: 14:25 - 17 Aug 2005 Post subject: |
Thanks for that Keith, I am trying to avoid changing anything that Honda put in my baby.
I was hoping it wasn’t the can, I have heard some horror stories from people taking their bikes on Dyno’s and how they perform afterwards. Could be bullshit. ____________________ Cleverly disguised as a responsible adult.
| craigs23 |
 craigs23 Mr Muscle
| Kickstart |
| killa |
 killa Won't Shut Up
 Posted: 15:47 - 17 Aug 2005 Post subject: |
Good info guys, I am 100% sure there is no non Honda bits in there.
TBH I have learned how to handle the bike with this and it does run sweet in the higher rev range, but it is increasingly annoying when a Golf GTI can have you off the mark because I am not getting the power to the floor I need. Sorry, not that I do this all the time, but it is annoying.  ____________________ Cleverly disguised as a responsible adult.
| craigs23 |
 craigs23 Mr Muscle
 Posted: 15:59 - 17 Aug 2005 Post subject: |
lol, gives them a head start and they think they're winning, until the power kicks in anyway, then, no chance.
Bye Bye GTi....  |
The last post was made 21 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
