| Twisted2004 |
 Twisted2004 Nova Slayer
| Twisted2004 |
 Posted: 16:40 - 17 Aug 2005 Post subject: |
Just because the least seized will come out first, leaving the more stuck out to be a real pain to get out.
If you try and pull them out with pliers you will wreck them (probably) and I assume you do not have a compressor to supply air to blow them out. As such the easiest way is to just use the brake system itself to push them out, and getting them both out at the same time saves cleaning up one piston, replacing it then bleeding the system just to get the other piston out.
| Twisted2004 |
 Posted: 18:38 - 17 Aug 2005 Post subject: |
Yep, pretty much. May be worth putting the caliper in a plastic bag while you pump the pistons out, this way it limits the amount of fluid going everywhere. Once the pistons are out you can disconnect the caliper if it makes life easier for you. Use something like an old pad to press against the pistons to keep them coming out at the same rate. One will come out marginally before the other, but by that stage the other should be fairly easy to remove with minimal effort.
The seals may or may not be reuseable. Common problem is corrosion in the groove the seals sit in, pushing the seals hard onto the piston.
However, check the pins it slides on first. May well be that is the problem and they are easy to clean up without opening the caliper up and spilling fluid.
| Twisted2004 |
| Twisted2004 |
 Posted: 13:25 - 29 Aug 2005 Post subject: |
If you have bled the system through from empty then it is easy to get some air at the top of the system, around the banjo bolt into the master cylinder. Wrap a cloth around the banjo bolt, pull the brake hard and crack off the banjo bolt a bit and retighten it (quickly). This should get any air out.
The cloth is important to stop any fluid that comes out squirting over the bodywork.
keith ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
The last post was made 21 years, 27 days ago. Instead of replying here, would creating a new thread be more useful? |
