Brake Problems - 1982 Kawasaki GPZ 550 H2
Cerbera
PostPosted: 21:14 - 19 Aug 2005    Post subject: Brake Problems - 1982 Kawasaki GPZ 550 H2 Reply with quote
Hi everybody, this my first post so go easy on me!
I am looking for any advice on a problem I'm having with a restoration project.
I am rebuilding a 1982 Kawasaki GPZ 550 H2. We're having difficulties with the front brakes. When bleeding the brakes we are unable to get a pressured lever, there is some but not enough.
The calipers have been fitted with new pistons and seals. Braided hoses are fitted and have no leaks. The original Kawasaki master cylinder seals had gone so we fitted one from a Suzuki Bandit but still unable to get a brake.
Any help with this would be appreciated.
PostPosted: 21:53 - 19 Aug 2005    Post subject: Reply with quote
Would think the Bandit m/c would have a sufficient bore to pump enough fluid for those 2 little single piston calipers.
Try tapping the brake lines and then pull the lever very slightly. You can sometimes get a lot of air out from the brake lines via the m/c and reservior. You get tiny bubbles, but sometimes enough to make a lot of difference.
Also try pulling the brake lever fully and then crack off the top banjo bolt and then do it up again. It is easy to get air trapped around the banjo bolt (often one of the highest bits of the system) and this gets it out.
gavin
PostPosted: 23:35 - 19 Aug 2005    Post subject: Reply with quote
try reverse bleeding them: connect a pipe to the bleed nipple and slowly fill the system from the nipple to the reservoir using a ezibleed pressure system or a large syringe connected to the pipe.
when you have a reservoir full of fluid close the nipple so its not quite stopping the flow and then pump the lever. it should go firm fairly quickly.
PostPosted: 00:44 - 20 Aug 2005    Post subject: Reply with quote
The above can work well.
Sometimes they can just be git though, and you need every trick in the book.
Jrod
Page 3 Girl
PostPosted: 01:06 - 20 Aug 2005    Post subject: Reply with quote
Yep, took me fu*king ages. Sad
Cerbera
PostPosted: 12:12 - 20 Aug 2005    Post subject: Reply with quote
Thanks to all who replied Very Happy
Unfortunately I have to work this weekend so we will not get a chance to try until Monday!
Thanks again, I'll keep you posted.
mchaggis
PostPosted: 21:58 - 20 Aug 2005    Post subject: Reply with quote
Eye protection is a good idea for the above procedure. It missed my eyes, but not by much. Embarassed Stripped, cleaned and bled my front brake today and the difference is astounding.
What struck me as odd was when I was filling the system back up and pumping the pistons back out, the level didn't drop even though I got a load of bubbles from the master cylinder.. Thinking
I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 53.79 Kb
