honda cg125 carb
dobin
PostPosted: 15:52 - 20 Aug 2005    Post subject: honda cg125 carb Reply with quote
water got in to my honda cgs carb i would just like to no if there is a way to stop this when its raining
mr.z
PostPosted: 16:01 - 20 Aug 2005    Post subject: Reply with quote
The only way water should be able to get in the carb is through the tank... and possibly through the brether pipe (unlikely unless its been binned)
So a case of just being more carefull when filling up..
It may have gotten in through the airbox, maybe a breather hole is blocked allowing it to fill up? somehting like that...
Certianly not a problem i encountered, i did end up with the plug getting wet quite often :/ (wd40, clean the recess the plug cap rests on)
mchaggis
PostPosted: 16:03 - 20 Aug 2005    Post subject: Reply with quote
Got in? How can it get in? Confused
If it's in the fuel, then don't open the fuel cap in the rain unless you can shield it. Forecourts have roofs.
I didn't think the CG tank was prone to getting water in however. Thinking Anyway, to drain it, use the drain screw on the bottom of the floatbowl, and catch the petrol in a clean, dry jam jar or similar. Then you can see whether it has any water in.
Don't forget to do up the drain screw before you turn the fuel tap on again. Embarassed
I must not be a troll...
Mmmm, Guinness
dobin
PostPosted: 16:09 - 20 Aug 2005    Post subject: Reply with quote
Mr. Green
I think it might have been done buy the previous owner because i have been in seroius rain yet
The last post was made 21 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 39.91 Kb
