More varadero probs - now its not starting all the time
asphaltic99
PostPosted: 10:47 - 21 Aug 2005    Post subject: More varadero probs - now its not starting all the time Reply with quote
Twisted Evil
Since my Vara went in to the garage it won't start properly and I have to keep bumping it. All I hear is a click from under the L/H panel under the seat. Starter motor doesn't seem to be turning. When I try to start the bike with the lights on they nearly go out.
Have checked the battery and its OK (well seems to be, I connected it to a charger and the indicators showed FULL).
But if I go on a longish run, I can turn the ignition off and 5 times out of 10 it will start OK though Question
Could it be something to do with the fact that the forks were taken off the bike recently and the garage have done something wrong when putting it back together Question Someone mentioned it might be a relay of some sorts thats causing the problem Question Or could it be more serious Question
i am a dirty sod who bothers women.
mr.z
PostPosted: 14:47 - 21 Aug 2005    Post subject: Reply with quote
Right...
When you say it just clicks thats the classic "flat battery" sign, starters do use a hell of allot of power... yours could be on its way out (the battery)...
Try chargeing it for a couple of hours anyway and see if it helps..
Depending on how its wired the kill switch could be playing up, or the ignition switch maybe?
Could be various loose wires...
To be honest your best takeing it to the garrage, tell them its only been doing it since its last visit and you want it sorting.
Mark_petty
PostPosted: 19:54 - 21 Aug 2005    Post subject: Reply with quote
My bike had a faulty starter motor. It made a clicking noise, if you are brave enough hit it hard with a hammer and it will start (if its the starter motor)
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
asphaltic99
PostPosted: 21:22 - 21 Aug 2005    Post subject: Reply with quote
I felt like using a sledgehammer on it earlier.......the whole bike that is.
I don't even know where the starter motor is on the bike. There's some wires that disappear into the LH crankcase above the front sprocket - maybe its in there? Think I will give it a kick in the morning - where's my steel toecaps?
Mr Z - I had the battery on charge for a while a bit earlier (low charge, about 4 hours), fitted it back onto the bike, but still nothing. The charger indicator showed the battery as being fully charged. I did tell the garage when it first started doing it, got the normal reply "well it was OK when we had it, but if it still plays up then bring it in and we'll check it out." Which to me translates as "Bring it in and we'll get more £££ out of you".
the grim reaper
PostPosted: 22:02 - 21 Aug 2005    Post subject: Reply with quote
Don't believe the indicator on battery chargers, they often sauy that a knackered battery is full. The voltage might be high enough but it's the ability of the battery to supply current that starts the bike.
If I were you, I'd jump start it off a car WITHOUT THE ENGINE RUNNING, if it starts, there's nothing wrong with the starter system.
Cheers
Grim
The last post was made 21 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 46.62 Kb
