Low Oil Crisis!
veeeffarr
PostPosted: 10:34 - 22 Aug 2005    Post subject: Low Oil Crisis! Reply with quote
Basically, checked the Oil on my 2001 CG125 last night and the oil is exactly at the minimum level (The bottom of the cross hatching)
I HAD to ride it into work this morning unfortunately, and I've never filled up the oil before, so I don't know what oil is in there (Can't contact the previous owner)
What should I do? I don't really want to ride it back again at min oil as I'm sure it's not doing it much good?
Should I just bite the bullet and buy Castrol 10w40?
Do I put the oil in where the dipstick goes or would that be bad?
Cheers,
Toby
mchaggis
PostPosted: 10:44 - 22 Aug 2005    Post subject: Reply with quote
The oil goes in the dipstick hole. While riding a CG with low oil won't kill it immediately, eventually it will nip up. I'd just bite the bullet and get some Castrol GTX. Ideally the oil wants replacing every 1000-1500 miles.
I myself have reverted to stuff which costs £3 a gallon rather than £10, and haven't noticed anything out of the ordinary. After mine seized due to my huge stupidity, I emptied the oil and only got 300ml, from a 1.1 litre sump. Embarassed It was being mercilessly thrashed all the time too and had been running like that for a good few hundred miles before the problem really occured. It had been giving me signs which I merrily ignored too. Doh! Still, it runs as well as it ever did now, with just an oil change.
I must not be a troll...
Mmmm, Guinness
PostPosted: 11:37 - 22 Aug 2005    Post subject: Reply with quote
Any oil is better than no or low oil. I would also use GTX in a CG125, it is much better quality that what they were originally designed to run on anyway.
veeeffarr
PostPosted: 11:40 - 22 Aug 2005    Post subject: Reply with quote
Well what I've been doing to check the oil is stand the bike on the centrestand, and start it up and let it run for a couple of minutes, giving it a few revs, and then shutting it down and checking the oil straight away, is this right?
map
Mr Calendar
PostPosted: 11:59 - 22 Aug 2005    Post subject: Reply with quote
No.
Engine and oil should be cold when checking level.
Leave on centre stand to cool (as said in another thread, have a cup of tea/coffee/whatever). You have to give the oil time to go from the top of the engine back into the sump. Some of the pathways for this are very, very fine (ok, maybe not in a CG but good practice for all engines). Then go to check. From what I remember of the CG the oil cap contains the dipstick. Unscrew the cap and clean the stick. Then push if back to the top of the threads (do not screw it back in). Take out and check the level of the oil. Top up as required - always leave enought time for the new oil to reach the sump, it takes a bit longer than you think it should. When level ok then screw the dipstick back in.
P.S. Please check in the manual about not screwing the dipstick back in to check the level. This was the case for the older models. I doubt if it'll have changed but best make sure (in case, for example, Honda are saving pennies by making a shorter stick).
veeeffarr
PostPosted: 12:12 - 22 Aug 2005    Post subject: Reply with quote
Oh, bollocks, crisis over then Smile
mchaggis
PostPosted: 13:03 - 22 Aug 2005    Post subject: Reply with quote
You can tell if it is really having a problem with low oil, it will be more noisy and hotter than normal, and if it is getting to the seizing stage, it will usually shudder and hiccup as it nips up a little. Mine only seized after 1/2 an hour on WOT with bugger all oil in, though I might have been lucky. Smile
CG engines are tough little buggers.
Mmmm, Guinness
bish777
PostPosted: 18:01 - 22 Aug 2005    Post subject: Reply with quote
Over the last 6 months of unemployment, i learned that its better to change oil for the £7 quid a gallon stuff rather than leaving the oil in for another 5000 miles.
Keeping changes regular is more importnant than what you put in, especially for a bike like the CG. It would probably be perfectly happy with 2.50 a gallon 20/50 super cheapo, as long as you change it every two thousand miles.
GSXR1100J
mchaggis
PostPosted: 22:51 - 22 Aug 2005    Post subject: Reply with quote
Whistle
It is. Laughing
It was just some cheap rubbish left over from my mum's old Audi 80 from when it burnt out a piston ring. Cost to me = £0.00 Mr. Green There's four oil changes to a gallon with a CG too. Thumbs Up
Mmmm, Guinness
kiss_my_shiny_metal_ass
PostPosted: 14:26 - 25 Aug 2005    Post subject: a sollution to ur oil problem Reply with quote
buy 4 stroke oil mate and there should be a different tank for the oil and u can bleed the remanding oil out of it and put in the new stuff thats if its a four stroke if its not, then buy 2 stroke and do the same with that , but u dont have to bleed it u can just put the new stuff in
The last post was made 21 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 67.79 Kb
