Mito ignition problems
Rents
PostPosted: 10:33 - 23 Aug 2005    Post subject: Mito ignition problems Reply with quote
Hi guys,
My Mito ('95 Evolution) won't start. When the starter button is pressed, nothing happens. It's not the battery, because the lights etc turn on fine and the engine won't even try to turn over.
Also, it won't roll start (which I've done very easily in the past). There seems to be no spark in the chamber.
I've changed the spark plug, which didn't help.
Does anyone have any ideas about what it could be? I'm probably going to end up taking it to the place that services it, but I'd like to try absolutely everything simple before it comes to that.
I've got the mito service manual, and that narrows it down to being the coil or the starter. What can I do to test these things? Unfortunately I don't have all the suitable tools that I should. Any other possibilities?
Thanks. Smile
PostPosted: 11:17 - 23 Aug 2005    Post subject: Reply with quote
It takes far less power to operate the lights than to operate the starter motor. Do you here a click when you press the starter button?
Think the Mito is like the RS (and a few other 125s) in that the kill switch circuit does not disable the starter motor. As such there are loads of things that can stop it from generating a spark.
On some bikes I would say it would be the side stand cutout switch, but I don't think the Mito uses one. On most bikes these disable both the starter motor and the ignition system.
Find the starter motor and follow the large wire from that up towards the battery. You should find the starter relay. That is probably the most likely part to fail to stop the starter motor working. But you can check this by checking for a voltage at the starter motor when the ignition is on and you are pressing the starter button.
Rents
PostPosted: 13:06 - 23 Aug 2005    Post subject: Reply with quote
Thanks for your prompt reply KickStart!
No click.
Thanks, I'll try it tomorrow when it's light. However, if it's a problem with the starter motor, would that prevent me from roll starting it? I don't see the connection between a starter motor problem and having no spark in the cylinder.
PostPosted: 13:47 - 23 Aug 2005    Post subject: Reply with quote
That you are not getting a click from the starter relay suggests that the starter motor is not getting any power at all. Unlikely the starter motor is the problem.
A starter motor fault should not affect the ability to bump start the bike.
I will have a look through the wiring diagram tonight when I get home, but it sounds like some sort of cutout to me. Quite possible that there is a seperate fuse that protects the starter and ignition system and that this has blown.
planet rider
PostPosted: 18:02 - 23 Aug 2005    Post subject: Reply with quote
it could possibly be the starter solinod (or how every its spelt) buy your battery(small gold thing) has happend to my planet before just make sure that the wires have not come loose there for all the lights will work but there will be no power to start the bike
Xj 900
no_shad
PostPosted: 00:22 - 24 Aug 2005    Post subject: Reply with quote
Sounds like the classic sticking solenoid, take the seat off and give it a good poke.
Rents
PostPosted: 12:37 - 24 Aug 2005    Post subject: Reply with quote
Thanks for the helpful replies guys.
Unfortunately I'm always at work while it's light, I'm going to have to wait till the weekend to check everything.
I'll start with kicking it Cool
The last post was made 21 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 53.72 Kb
