Exhaust mounting problems/engine damage
mr jamez
PostPosted: 15:13 - 23 Aug 2005    Post subject: Exhaust mounting problems/engine damage Reply with quote
Just recieved an engine from a friend that is going into a TT600, one of the mounts where the exhaust headers bolt to is smashed. As you can see the one on the right (upper mounting) is the problem, will it hold the header on OK? There is about half of it left and the raised area that it sits against is also missing.
https://img233.imageshack.us/img233/197/dsc013483cy.jpg
Seems to be other bits of small damage around that area so I assume there was a frontal impact which did this, they are cunts really as it isn't hard to notice that; was described as excellent condition I seem to recall. Makes me a bit concerned as to what else is broken.
map
Mr Calendar
PostPosted: 15:24 - 23 Aug 2005    Post subject: Reply with quote
FWIW I'm told if you make a bit of a mould then you could use something like JB Weld. However, from another source I've been advised that this can be quite brittle (easy to remove). Just passing this info on in case it is any use. Could try, it can't make it any worse, could it?
mr jamez
PostPosted: 16:17 - 23 Aug 2005    Post subject: Reply with quote
The place in question have offered to pay for the welding (£50 they reckon)
Will the heat kill the headgasket?
PostPosted: 16:39 - 23 Aug 2005    Post subject: Reply with quote
To be honest I think you need to go and speak to a good local welder who can repair alloy (not many can). It should be possible, but to be honest I would not be happy spending £650 on a damaged engine.
Pay by credit card?
ZRX61
Victor Meldrew
PostPosted: 14:58 - 24 Aug 2005    Post subject: Reply with quote
It needs to be built up with weld, shaped, drilled, tapped etc. The head will need to be removed for this & then skimmed to remove any weld from the mating surface.
Or just find another head.
PostPosted: 16:57 - 24 Aug 2005    Post subject: Reply with quote
And the main point to buying this engine was the trashed head on the original engine.
ZRX61
Victor Meldrew
PostPosted: 19:57 - 24 Aug 2005    Post subject: Reply with quote
Return it.
The last post was made 21 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 53.39 Kb
