Plastic welding
Jrod
Page 3 Girl
PostPosted: 20:54 - 25 Aug 2005    Post subject: Plastic welding Reply with quote
Well this is my second attempt at it. First time i tried to plastic weld something it ended up f*cked. Mr. Green Laughing
Welded but looks a mess. Razz
https://www.bikechatforums.com/files/sp_a0009.jpg
Alot of rubbing later...
https://www.bikechatforums.com/files/sp_a0012.jpg
https://www.bikechatforums.com/files/sp_a0013.jpg
Smile
plugger147
PostPosted: 21:10 - 25 Aug 2005    Post subject: Reply with quote
looks good for such a big weld. Thumbs Up
a bit of stopper and a good filler primer and it'll be perfect. Very Happy
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Jrod
Page 3 Girl
PostPosted: 21:12 - 25 Aug 2005    Post subject: Reply with quote
What's stopper? Embarassed
Basically thr whole piece below weld wasn't attached anymore.
plugger147
PostPosted: 21:18 - 25 Aug 2005    Post subject: Reply with quote
it's a kind of filler that you can rub down by wet flatting,it fills all the tiny inperfection's.
Jrod
Page 3 Girl
PostPosted: 21:27 - 25 Aug 2005    Post subject: Reply with quote
Wet flatting? Laughing
Embarassed
-Savage-
PostPosted: 21:28 - 25 Aug 2005    Post subject: Reply with quote
looks a good job. i had a go at aluminium wielding on my landrover there last year! holy god it was a mess lol
plugger147
PostPosted: 21:33 - 25 Aug 2005    Post subject: Reply with quote
wet flatting=light sanding with wet and dry paper(400 grit oughta do fine)and water on the stopper and then another wet flat with 1200 over the primer. Thumbs Up
Jrod
Page 3 Girl
PostPosted: 21:38 - 25 Aug 2005    Post subject: Reply with quote
Cheers mate! Mr. Green
plugger147
PostPosted: 21:40 - 25 Aug 2005    Post subject: Reply with quote
no probs,don't forget to post the picture's when it's done.
riichy
PostPosted: 23:53 - 25 Aug 2005    Post subject: Reply with quote
keep it white looks cool. Thumbs Up
good job on the weld only thing i can weld is steel and thats at college ......
.......... PLOD ............ zx636 2004
SoND
PostPosted: 02:32 - 26 Aug 2005    Post subject: Reply with quote
What do you need to plastic weld?
Is it expensive?
Jrod
Page 3 Girl
PostPosted: 14:36 - 26 Aug 2005    Post subject: Reply with quote
I needed to plastic weld the spare front fairing I had. No it wasn't expensive it was free. Mr. Green
PostPosted: 14:48 - 26 Aug 2005    Post subject: Reply with quote
Basically something to melt the plastic and merge the 2 pieces together, preferably with something to melt some extra plastic in to replace the stuff that goes up in smoke.
You can do a basic attempt with a soldering iron. However the results will not be strong and it stinks while you are doing it (and the fumes are probably poisonous).
jonnay
PostPosted: 15:06 - 26 Aug 2005    Post subject: Reply with quote
I left my soldering iron on a block of polystyrene in the shed once, whilst I went to do something. It was turned on.
After going back in and trying to turn it off, I couldn't see clearly for the next 15 minutes, and I was coughing for the rest of the day Embarassed
Not reccomended...
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
Robin
PostPosted: 20:22 - 27 Aug 2005    Post subject: Reply with quote
Is it expensive?
I've done it using a soldering iron and the spare bits from an Airfix kit, needs a bit of practise though. I'm sure there are better ways.
Last thing I did was the dogs water bowl while out camping, used a tent peg and the gas stove, didn't last long, but got the dog home Mr. Green
The last post was made 21 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 88.71 Kb
