Riding in severe rain?
veeeffarr
PostPosted: 12:44 - 26 Aug 2005    Post subject: Riding in severe rain? Reply with quote
As anyone Northwest will tell you, the past couple of days have been a real shitter for rain, and I've been riding all the way through it.
Done about 100 miles in the past couple of days and I'm just wondering if there's anything I can get that will stop my visor from becoming useless when its rained on? I can't even lift it up because I wear glasses and they get wet too! Sad
Also, as I've been staying round my girlfriends, it's been out all night in the rain for a couple of days, is there anything I need to do to it to protect it? Is there anything bad that can happen from leaving it out in the rain? (was out in last nights downpour, started first time).
Cheers,
Toby
JodieWodie
Reflective Banana
PostPosted: 12:51 - 26 Aug 2005    Post subject: Reply with quote
I use Holts Anti-Mist and Water Repellent.
You can see a little improvement in the vision, but I don't think anything you buy will be as good as a set of windscreen wipers Wink Mr. Green
Coat your bike in wd40, especially underneath pipes..wash it off when the weather improves.
(Also, another thought, why not invest in some kind of light-weight tarp thing, stuff that down your jacket. When you get to gf's house, dry the bike off and tie the cover round it. Will do some good. Better than nothing. We recently bought 2, they are way big enough, blue, about £10 each as I recall. Whoops !! Another edit - B&Q btw) Thumbs Up
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
yorkshirelad3
PostPosted: 12:52 - 26 Aug 2005    Post subject: Reply with quote
if its a 4stroke it will almost always fire up, however if mines been rained on heavy i try and clean and re libe everything as sonn as to avoid anything going manky or rusty.
i rode back from scarborough back in may and got caught it a horrible rain downpour, i couldnt c further than 2 metres and was following in the car infronts tracks as the water was making the bike skip around, i was waiting for a bridge to pull up under but no luck.
just take it steady and avoid the white lines, black joining lines and man hole covers!
i slipped on a white line only 2 weeks ago, it really does hurt.
PostPosted: 13:00 - 26 Aug 2005    Post subject: Re: Riding in severe rain? Reply with quote
Nothing specific, I think part of your problem is that you aren't going fast enough on a CG for to run the water off your visor by turning your head to one side. An anti-fog insert/treatment on the inside of your visor can help. You can also get a thing called a 'v-wipe' which is like a bit of windscreen wiper blade that fits on your left index finger.
I have seen treatments meant for car windscreens that is supposed to make water roll straight off. I have no idea if it works on bikes.
In my experience, if it is REALLY raining (like when there is water running down the inside of your visor), there isn't a whole lot you can do other than crack open your visor about 1/2 an inch, slow the hell down and lift your visor so you can peer under it as you approach junctions etc.
It will start going rusty after a couple of years, sometimes your clocks or indicators will steam up if they don't have a very good seal. I got my first lockup only two months ago. In the other 11 years I have been riding, my bikes have been parked outside. It will not bother your bike at all unless it is a Harley (which will rust overnight) or Italian (which will have a tantrum and refuse to start).
JodieWodie
Reflective Banana
PostPosted: 13:03 - 26 Aug 2005    Post subject: Reply with quote
I agree with stink, I always have my visor open a crack, stops the misting. Either that or don't breath for your journey !! Laughing
I use my gloves as a windscreen wiper too. These were from J&S and have like a chamois leather patch down the outside edge of both hand to swipe across your visor. They work a treat Thumbs Up Ask in shops or on the net for something similar.
map
Mr Calendar
PostPosted: 13:51 - 26 Aug 2005    Post subject: Reply with quote
FWIW I think you should be able to get a little gadget that fits over your glove thumb and has a little piece of wiper blade on it. Useful for clearing water off the visor. I think you can get some gloves with a similar thing built into them (I know an old pair of mine had).
As for the bike try the Scottoil FS365, although you're supposed to put in on when the bike is dry as water washes it off. There's also prducts like ACF-50, but I haven't tried this myself.
veeeffarr
PostPosted: 14:03 - 26 Aug 2005    Post subject: Reply with quote
Thanks for the advice!
My visor isn't steaming up at all apart from at a standstill, but once I get past 10mph the steam is just 'sucked' out... It's a great lid I have Smile AGV Anti Fog Smile
I have a sort of suede patch on my glove which kind of works, but will try the wiper blade thing.
I'm quite careful over what I put on my bike so I don't get condensation, so I think I'll invest in a proper one.
I have an Oxford cargo net, which I put my rucksack in over my pillion seat so it doesn't give me a back injury if I come off... And I've just started putting it in a bin bag on the way, starting to think like a biker now Very Happy
My clocks are fine, keeping a nice seal and not steaming up at all, which is good Smile
fozberry
PostPosted: 14:39 - 26 Aug 2005    Post subject: Re: Riding in severe rain? Reply with quote
I use 2 things for maintaining visibility in wet/cold weather:
Arrow Spray furniture polish on the outside of my visor.
Arrow Spray washing up liquid on the inside of my visor.
Furniture polish works because of the wax in it. Water doesn't stick so well to it, and beads up and slides off much easier and faster than it would on a 'clean' visor. Also, dead flies can be wiped off much easier! Thumbs Up
Dunno how the washing up liquid works, but there is a knack to it. A lot of people try putting some on, then wiping off the excess - this doesn't work very well at all and isn't worth the hassle. But it is really easy to apply:
1. Buy a big bottle of very cheap washing up liquid. Last time I bought one it was 19p from Tesco.
2. Get yourself a squirty bottle - the sort people use to water plants with - make sure it's got a good fine mist spray. I think mine cost 99p from B&Q.
3. Fill it with a very strong mixture of water and washing up liquid (3 parts water, 1 part washing up liquid) and shake well.
4. Spray some on your visor and clean it as best you can using some kitchen paper or whatever.
5. Spray on another coat of washing up liquid on the indside only and leave it overnight (or at least a couple of hours) to dry. DO NOT wipe it off.
Things to watch out for though - when you first put your visor down after a treatment, it will have a residue on it and look dirty and you'll probably want to wipe it back off again, but don't! With your visor down and breathing normally, the residue will clear after a couple of minutes.
Also, please please please make sure you don't leave any washing up liquid on the outside of the visor - I did this once and it started to rain - I couldn't see through the bubbles!! Shocked
One coat normally lasts me about a week, although if it's particularly cold or wet, this gets reduced a bit.
This all sounds like a ball-ache, but you get used to doing it (I only spend about 3 minutes per week cleaning my visor now) and it's by far the cheapest way to keep your visor fog free!
HTH
fozberry Cool
PostPosted: 15:46 - 26 Aug 2005    Post subject: Reply with quote
On a similar theme, you want to be putting your mobile phone in a zip-lock plastic bag. You don't even need to take it out of the bag to use it.
PostPosted: 16:04 - 26 Aug 2005    Post subject: Re: Riding in severe rain? Reply with quote
Trying to remember the brand name of the stuff (Rainex?), but it does have a good reputation and seems to work well. However it is not recommended for use on plastics. That said plenty of people seem to use it without any problems.
Glasses are a pain in the rain. One thing I did not like about my last Shoei lid was that it failed to seal properly around the edge and allowed water inside, regularly getting drops on my glasses. Really must try contact lenses again some time.
Wooly R6
PostPosted: 16:09 - 26 Aug 2005    Post subject: Reply with quote
washing up liquid is a treat - works well until the visor gets pretty dirty - i always wash mine as soon as i get home so its ready to go next time i ride
deputy
PostPosted: 16:45 - 26 Aug 2005    Post subject: Re: Riding in severe rain? Reply with quote
Rainex is correct, and I am fairly sure you can now get a version specifically for plastics.
DAF
PostPosted: 22:59 - 26 Aug 2005    Post subject: Reply with quote
FogCity visor inserts work really well. Can't get them to mist even if I try.
2005 Yam Fazer (FZ6-S)
bish777
PostPosted: 23:18 - 26 Aug 2005    Post subject: Reply with quote
If you just rub your visor with the flat of your palm it breaks the surface tension of the water and the wind blows most of it off i find.
I'm a specco and get my glasses fogging or getting wet, i find just having your visor open a crack is the best compromise.
GSXR1100J
The last post was made 20 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 90.11 Kb
