Wheel balance question............sort of!!!
wildcat
PostPosted: 16:23 - 27 Aug 2005    Post subject: Wheel balance question............sort of!!! Reply with quote
Ok what will happen if i take the wheel balace weights off my bike?
Will it be ok til next week when i can get it redone?
I just went out to put silver rim tape on, and theres a weight just where the tape goes.
Thanks in advance.
Kat
kawashima
PostPosted: 16:45 - 27 Aug 2005    Post subject: Reply with quote
I think you can ride slowly. Riding fast on highway may not be safe. I think you can try and check until how fast you can ride smoothly.
Teaman
PostPosted: 16:59 - 27 Aug 2005    Post subject: Reply with quote
best way to explain it is if you have a cyle wheel, if so hold the axle and get someone to spin the bugger realy fast then turn it from side to side.
You should have done this at school.
now all you have to do is add some weight to one side youll notice it trys to lean that way as if the wheel is oval.
you have to remember that it has less effect because the wheel is narrow,
your motorbike will be ok at slow speeds and then shake the living crap out of you at fair to high speeds
dont do it mate, or as another option, mark on the side of the tyre the exact place the weight is, remove it carefully then after adding the rim tape glue it back on
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
The last post was made 21 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 35.56 Kb
