Bar shake
mrchips
PostPosted: 19:01 - 27 Aug 2005    Post subject: Bar shake Reply with quote
My GPZ500S seems to have developed a bit of a problem in thefront end. At around 50mph the bars shake, now you cannot really feel this unless you let your hands off the bars and if you do the bars shake quite vioilently. Not fully tank slapping but maybe a good half turn anyway. I have checked the yoke forks wheels etc and nothing is lose, fork seals were replaced recently and so on. Can't think what it could be. Any ideas?
Northern Irish? www.nibikers.com
no_shad
PostPosted: 19:23 - 27 Aug 2005    Post subject: Reply with quote
Balance weight may have came off the wheel.
Bearings could be gone/going.
Warped disk.
Ding in the wheel.
Could always try heavier bar ends.
White Noise
Mr Dudwee
PostPosted: 19:55 - 27 Aug 2005    Post subject: Reply with quote
what condition is the front tyre in? i believe that either stinkwheel of kickstart where having a similar type of problem, they replaced the front tyre and it went away
WN
mchaggis
PostPosted: 22:31 - 27 Aug 2005    Post subject: Reply with quote
IIRC, the tyres on a GPZ really want replacing by the time they've worn down to 2 mm. For some reason, the handling is really cocked up with a worn tyre.
I must not be a troll...
Mmmm, Guinness
White Noise
Mr Dudwee
PostPosted: 22:44 - 27 Aug 2005    Post subject: Reply with quote
heres stinkwheels post
https://www.bikechatforums.com/viewtopic.php?t=54871&highlight=gpz
hope it helps
WN
biker-dj
PostPosted: 00:37 - 29 Aug 2005    Post subject: Reply with quote
How strange.. I had this the other day on my GPZ 500S - tread was ok tyres seemed ok checked the tyre pressure well low - whoops - topped up pressure problem solved. Hope this helps Wink
Ride with the music!
PostPosted: 19:36 - 29 Aug 2005    Post subject: Reply with quote
What they said. Easy fixed.
I keep forgetting about it too.
map
Mr Calendar
PostPosted: 21:02 - 29 Aug 2005    Post subject: Reply with quote
Just another vote for checking the tyres - that's the wear and the pressure. It's surprising how a little variation in pressure can make a big difference on the road. HTH Thumbs Up
The last post was made 21 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 56.52 Kb
