How deep into corners do you brake?
cunni
PostPosted: 16:18 - 28 Aug 2005    Post subject: How deep into corners do you brake? Reply with quote
How late do some of you guys brake a sports bike into corners, not how late in a straight line before letting off and tipping in, but how hard to you use the brakes after tipping in?
Do any of you get on the brakes just before tip-in and carry loads of front brake right up to the apex?
Just wondering, because on track, the slick tyres are soooo good, you can carry loads of front into a corner. Just wondered what the norm was on the road?
TL1000R Parts For Sale!
cc123
Geez a joab?
PostPosted: 16:38 - 28 Aug 2005    Post subject: Reply with quote
I've found myself doing less and less braking these last few weeks as I'm more confident in downshifting and using the rear brake only if I have to mid corner. I've found the confidence I lost after my crash again... Mr. Green
Only on the rare occasion I use heavy front brake if I've read the corner wrong but even then its very late into a corner.
Never been on a track (will change soon Wink ) never mind using slicks. My 207's work more than well enough, wet or dry.
Old bikes >>> https://www.bikepics.com/members/cc123/
cunni
PostPosted: 16:40 - 28 Aug 2005    Post subject: Reply with quote
do you not find the back brake makes you back end lock up and swing out in corners, or do you only feather it?
Gazdaman
I did a trackday!!!
PostPosted: 16:44 - 28 Aug 2005    Post subject: Reply with quote
I'm still braking while I'm starting to tip it in, then smoothly releasing and keeping the power steady then full throttle out.
On trackdays you really see people doing all sorts of silly things while braking. As you'll know on snett, the corner at the end of the start/finish straight. People are braking FAR too early. I was starting to brake between the 2 and the 1 markers, whereas others were braking before the 3 marker.
Gaz
cunni
PostPosted: 16:48 - 28 Aug 2005    Post subject: Reply with quote
I know what you mean!
cc123
Geez a joab?
PostPosted: 16:50 - 28 Aug 2005    Post subject: Reply with quote
Only feather it, if I get it wrong then I just lean the bike somemore as I'll know it will go round the bend, now and again I get caught out and have to give heavy front to shed some speed before taking a corner.
I locked the front when I crashed but my new Ninja has better front end feel but I don't feel the need to use it all, downshift, light rear brake and lean the bike over....sorted!
tatters
Exxon Valdez
PostPosted: 16:54 - 28 Aug 2005    Post subject: Reply with quote
braking????
whats that? Laughing
Suzuki
Roger
PostPosted: 17:51 - 28 Aug 2005    Post subject: Reply with quote
I usually do most of my braking before i've leant in to my "settled" position in the corner. ie... braking as i'm tipping in, and then release as the bike gets down to the cornering angle.
However, I have a few times kept braking right up to the apex, not through choice, but necessity. Scary experience to do it on the road, and not one i'm in a hurry to repeat, but it got me round the corner in one piece.
Rossi brakes to the apex of every corner practically... Confused
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
sickpup
Old Timer
PostPosted: 18:42 - 28 Aug 2005    Post subject: Reply with quote
All the way in.
VFR400UK
PostPosted: 18:46 - 28 Aug 2005    Post subject: Reply with quote
On the road i brake when upright, then stop braking, adjust my footing a tip it into the bend.
The only exception is if i've missjudged a bend in which case i brake right up to turn in and feather the front brake a bit as i turn in.
There is no real excuse for mid corner braking, it tends to lead to accidents which 9 times out of 10 would have been avoided by leaving the brakes well alone and cornering harder.
Section59
PostPosted: 19:44 - 28 Aug 2005    Post subject: Reply with quote
It all depends on the corner, if you brake the same for each corner, you're gonna end up crashing it rather quickly, i would imagine..
Tracks will be easier, if the track isnt the Nurburgring/Nordschleife that is.. Mr. Green
palmer
Fiddled Kiddy
PostPosted: 19:57 - 28 Aug 2005    Post subject: Reply with quote
would braking, letting off, then leaning in not be the best method? powering out as you pass the apex?
tony532
PostPosted: 19:58 - 28 Aug 2005    Post subject: Reply with quote
you do not brake when cornering
you obviously keep stuffing it up so to speak
VFR400UK
PostPosted: 20:00 - 28 Aug 2005    Post subject: Reply with quote
Thats the most senible way of doing it yes.
However with smaller bikes you can keep braking to some extent all the way up to the apex meaning your initial application of the brakes can be alot later.
With larger bikes it can be neccicary to 'trail brake' which is braking the rear slightly round the corner to help the bike turn.
Dracan
PostPosted: 20:25 - 28 Aug 2005    Post subject: Reply with quote
I'm fairly new to biking, so I'm sure someone's gonna correct me with this, but I brake before the bend, so that I'm back on the throttle when going around the bend. I find that the bike feels a lot more solid and stable when the throttle's on and I try not to brake at all when going around a corner. I do however keep my foot over the rear brake and if I do need to slow down a bit, I just very lightly touch the rear brake (nothing sudden though). If I'm going too fast for the corner I find that it's better to keep the throttle on and push away on the handle-bar nearest the curb to give a greater lean. Also I try and lean more towards the curb to compensate for me going in too fast. I try to never ever touch the front brake when going around a corner - I'm sure that's one sure-fire way to kick yourself off the bike. As I said before, that this is just what I've found in my short time of biking - if any of this is wrong, please correct me so that I can learn from it Very Happy
Cheers,
Dan.
Honda CBR600RR - 2004
PostPosted: 02:04 - 29 Aug 2005    Post subject: Reply with quote
Get the braking out of the way in a straight line and then turn in. Yes you can brake into the corner, but more chance of loosing the front and I am not that desperate to go faster.
AcIdBuRnZ
PostPosted: 03:06 - 29 Aug 2005    Post subject: Reply with quote
I've heard of some racers that drag on the rear brake mid corner in order to scrub off speed if they need to.
They put pressure half-way down the rear brake lever, rather than at the end, so braking force is reduced and therefore less likely to lock the rear wheel. Hope that makes sense.
Never tried it myself.
craigs23
Mr Muscle
PostPosted: 10:38 - 29 Aug 2005    Post subject: Reply with quote
400s don't go fast enough in a straight line to warrant the use of the brakes Wink so unless it's a road that I don't know, an unexpected hazard/slower traffic, my brakes rarely get a look in.
If I'm going hammer and thong ( Confused ) I get all my braking done when still upright.
flat spot
PostPosted: 10:50 - 29 Aug 2005    Post subject: Reply with quote
Depends on how much I've over cooked it.
mrchips
PostPosted: 10:51 - 29 Aug 2005    Post subject: Reply with quote
If I know the corner well I will be at the correct speed when I tip it in, if I'm not so familiar I will feather the front on.
Northern Irish? www.nibikers.com
PostPosted: 12:17 - 29 Aug 2005    Post subject: Reply with quote
On the road I always try and get braking done in a straight line - on the track I'm still conditioning myself to brake later into a corner oon track, but some of my best over takes have been done when I've outbraked someone, come up to the corner and thought 'hoh shit.... and just kept the brakes on /really/ late to make sure I don't lose my line.
On the road I, using the vanishing point system/other methods of reading the road I may brake while leant over a little if the road tightens, but try not to be too near any limits on the road, as those limits can easily be quickly reduced by a pot hole etc.
craigs23
Mr Muscle
PostPosted: 23:00 - 29 Aug 2005    Post subject: Reply with quote
...if I don't know a corner or stretch of road, I wouldn't ride it as if I did - I can always go faster next time.
Johnny GSX-R
PostPosted: 00:21 - 30 Aug 2005    Post subject: Reply with quote
Oh dear i've read some bollox on this forum in last few days..
It all depends upon the initial aproach speed, rider ability, bike ability, tyres, road condition, severity of the corner blah blah blah..
I chased a guy on a Gixxer 1000 last weekend and i tipped it in with a handfull of linked brakes on the Blackbird and got away with it.. There's a difference between what you "should do" and "what you can in reality get away with".
Sometimes i have gone charging into a bend farrr too quick and trailed the rear through whist getting back on the gas at the same time, this helps to settle the bike and squat it down.
Watch the on bike cameras of Rossi & Gibernau next time and watch them going through the corners & changing direction whilst under FRONT braking Shocked Shocked
In an ideal world YES get your braking done in a straight line, if you need to brake mid corner then use the back if poss, if you have to use the front then you'll need to muscle it a bit to alter the gyroscopic effect.
BenBray
PostPosted: 01:22 - 30 Aug 2005    Post subject: Reply with quote
I guess the only way to really know is to simulate an off road experience where you have less grip, That way when you transition to the road, you have a better feel for the bike.
Just something I read. Might be 100% wrong. And I'm hammered. Ben
Ben
california_rookie
PostPosted: 06:23 - 30 Aug 2005    Post subject: Reply with quote
I prefer to let-off the brakes quickly and smoothy just as I begin to lean the bike over. Never used the front break in a corner. Rear's handy, though. Thumbs Up
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
The last post was made 20 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 4.19 - MySQL Queries: 13 - Page Size: 129.38 Kb
