 simtrain Derestricted Danger
 Posted: 21:36 - 27 Aug 2005 Post subject: SR125 2nd gear problem |
Hi all, got a SR125, and having trouble getting 2nd gear. 1st gear and neutral no probs. but when pulling away in 1st, and flicking up for 2nd, the bike goes into neutral, and won't go into 2nd. Feels like the level won't move up.
Its a bit of a hit and miss affair, I pull away in 1st, clutch in, flick the lever up, get neutral, try flicking up again and it feels like something is stopping the lever going up. I release the clutch, then pull it back in and try again, same problem. I then drop into 1st gear and try again, still the same problem. Other times no problem with the gears. Any ideas?
Simtrain aka Steve |
 Posted: 17:24 - 28 Aug 2005 Post subject: |
Bump
Anyone? |
 Robby Dirty Old Man
 Posted: 00:04 - 29 Aug 2005 Post subject: |
linkage?I'm new to biking please forgive my ignorance. I thought that oil may come into it and have just filled up to the top, hopefully that'll solve one problem. As for being more positive with gear changing I think that is taken as ok, I wear he correct footwear (seems like for a 125 I overdress ) I will check the chain tightness first thing.
I much appreciate your reply, and will get back once I've gone through everything you have mentioned.
once again thank for the advice.
simtrain aka Steve
Thanks for replying
simtrain aka steve |
