making your own end can
Biker_Dene
PostPosted: 13:49 - 30 Aug 2005    Post subject: making your own end can Reply with quote
on a 4 stroke do you need back pressure from the exhaust or is that just 2 pokes?
i want to make my own end-can for my bike and wondering would just a empty tube work or do you need pipes inside it?
i could open up my standard can and rip the indies out , it has loads and loads of criss cross pipes inside it but would this just make it worse?
"RIDE LIKE A KNOB AND YOU'LL DIE"
K9 Suzuki Hayabusa
0ddball
PostPosted: 14:03 - 30 Aug 2005    Post subject: Reply with quote
It's not really back pressure you need it's gas speed.
ZXR750L
Biker_Dene
PostPosted: 14:06 - 30 Aug 2005    Post subject: Reply with quote
hmm can you explain more please mate lol
so will removing everything out of my current end can make my bike perform worse or better and will this cause the can to melt or anything ?
lol
thanks
dene Thumbs Up
K9 Suzuki Hayabusa
Milo
PostPosted: 14:12 - 30 Aug 2005    Post subject: Reply with quote
lol
thanks
dene Thumbs Up
Shaft drives rule. Razz
Biker_Dene
PostPosted: 14:13 - 30 Aug 2005    Post subject: Reply with quote
WTF
K9 Suzuki Hayabusa
PostPosted: 14:16 - 30 Aug 2005    Post subject: Reply with quote
Main effect will be to make the bike far noisier. It might well change the jetting requirements.
The average race can is just a straight through perforated tube surrounded by some glass fibre (like loft insulation).
zx636
PostPosted: 14:52 - 30 Aug 2005    Post subject: exhaust Reply with quote
I picked up a standard exhaust from Ebay for my R6 with the intention of ripping it apart inside.
Took ages to remove the internal pipework with lots of grazed nuckles.
End result.
Sounded like a harley with idigestion
performed like it was towing a harley with indigestion.
To set it up properly would have cost in Dyno time.
Far better to go buy an aftermarket exhaust where the manufacturer has done all the hard work for you.
feef
Energiser Bunny
PostPosted: 15:08 - 30 Aug 2005    Post subject: Reply with quote
2 strokes don't have "backpressure" as such.. what they do have is a shockwave of pressure that echoes off the inside of the fat expansion chamber part of the exhaust, and bounces off the exhaust port just before it opens, causing an additional lower pressure in the exhaust which, in effect, sucks out the exhaust gasses more effectivley, meaning more fresh fuel/air is in the chamber.
in a 4 stroke, a badly designed exhaust system can do a similar thing the wrong way, as an open end can, with no baffling/wadding, can cause an echo to help prevent gas flowiung out.
an effective end can will allow maximum flow, for minimum echo, hence the wadding to act as a damping material.
(oversimplified, so no techies bite my head off here)
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Biker_Dene
PostPosted: 17:26 - 30 Aug 2005    Post subject: Reply with quote
ok thanks for all youe help guys
ill figure something out.. Thumbs Up
K9 Suzuki Hayabusa
quik_d
PostPosted: 17:57 - 30 Aug 2005    Post subject: Reply with quote
i've been thinking about this for ages as i have a 600 bandit exhaust in my shed. I have a standard exhaust on my bike, and i had to re-rivit the end plate on after it worked loose. Now when i did this there is a little tube with holes in it that can be removed, is this a decibel killer kind of thing. There is a big box before the silencer which is the chambers etc so would it affect the bike if this were removed?
thanks guys
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
Milo
PostPosted: 20:34 - 30 Aug 2005    Post subject: Reply with quote
Apologies for whatever that post of mine was.
I cut down the quote to the needed bit and typed up a bit explaining that you'd need to re-jet the carb, etc, etc, and then submitted it. Confused
dave172
PostPosted: 20:57 - 30 Aug 2005    Post subject: Re: making your own end can Reply with quote
No, just 2 strokes
feef: 2 strokes dont have exhaust valves to open, and the back pressure in their exhausts is to push the fresh mixture back into the cylinder from the exhaust, as some escapes straight out the exhaust port before combustion stroke
sickpup
Old Timer
PostPosted: 23:27 - 30 Aug 2005    Post subject: Reply with quote
Except it isn't back pressure it's pressure waves. Two very different things.
SoND
PostPosted: 00:49 - 31 Aug 2005    Post subject: Reply with quote
Since there is a hole in the side of my exhaust, I was thinking about cutting off most of the side, take out the packing and pipes and replacing it with a straight pipe with holes drilled in it. Then put in new packing and weld a new piece of sheet on the side to fix the hole.
Will this in any way help my bike go faster, If I get it jetted and a new air filter?
Question
Johnny GSX-R
PostPosted: 01:42 - 31 Aug 2005    Post subject: Reply with quote
Oh dear 'DENE'...............
Its really not that simple.
4 strokes DO require a certain amount of back pressure to be effective. When i had my stockcar dyno'd it was producing less bhp with no silencer than it produced WITH.
When i put the race cans on the XX it was less pokey than with the standard cans Confused
Trust me on that one........ My brother makes his own cans for classic racers such as his MV Agusta 350 and Ducati 160's & 860GTS,, give him a call.
ZZRman
PostPosted: 07:11 - 31 Aug 2005    Post subject: Reply with quote
Want to burn valves then make your own can.....be very careful
0ddball
PostPosted: 09:23 - 31 Aug 2005    Post subject: Reply with quote
It depends on the context. Some well designed restriction in the exhaust can help low/mid range torque but for maximum power you do not want any back pressure at all. An open pipe of tuned length will always make more power than a silenced exhaust. The reason your engine produced more bhp (as you put it) is because your exhaust gas speed is too high in certain parts of the rev range and the exhaust is over scavenging. Part of the fresh inlet charge is passing through the inlet valve and straight out of the exhaust valve without being burnt. If you reduced the exhaust cam timing (duration or overlap) and run a straight through exhaust you would have as good, or better power than you have now but with lower fuel consumption and les noise.
ZXR750L
The last post was made 21 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 93.99 Kb
