nitromors
froggy128
PostPosted: 18:06 - 31 Aug 2005    Post subject: nitromors Reply with quote
has anyone had any experiance at using nitromors on bike frames etc.?
Robby
Dirty Old Man
PostPosted: 18:19 - 31 Aug 2005    Post subject: Reply with quote
I used it on a fuel tank. Did the job. Took a fair while, but I had 20 years worth of bodged resprays to work through.
Ducati750s
PostPosted: 12:32 - 01 Sep 2005    Post subject: Reply with quote
I used to use it all the while on steel and aluminium mountain-bike frames, it used to work a treat.
I'd keep it off any plastics though.
It's all about the torque...
VFR400UK
PostPosted: 12:47 - 01 Sep 2005    Post subject: Reply with quote
Keep it off your skin aswell! evil stuff!
Wear gloves and dab it on with a big brush that you can afford to wreck.
Keep it away from plastic rubber and fibreglass then scrape it all off.
You can use wire wool or a wire brush and only when you have scraped off all you can, otherwise you just gunge it up and splatter it all over yourself (speaks from expirence Laughing )
Liono
PostPosted: 18:21 - 01 Sep 2005    Post subject: Reply with quote
I used it to strip the old paint from the torque arm for my rear brake before I re-painted it. It was only a small area, but it worked well. I just sloshed a load of it on, left it a few minutes to do whatever chemical nastiness it does, then scraped if off with paint scraper. After a quick rinse and going over with a Scotchbrite pad to get off the bits I had missed it had worked nicely.
yzf750r
PostPosted: 18:22 - 01 Sep 2005    Post subject: Reply with quote
used it to take the factory paint off my rims, in order to polish them!
Works a treat! Thumbs Up
McGee
O RLY?
PostPosted: 18:23 - 01 Sep 2005    Post subject: Reply with quote
Jeez you have started 3 posts today and its like which one to reply to ..... Confused.
Its pronounced Jixxer!
shammon
PostPosted: 18:30 - 01 Sep 2005    Post subject: Reply with quote
Make sure you use gloves is Burns like fuk if it gets on your skin will strip paint of nicley use plenty with a stiff brush for the tuff bits.
froggy128
PostPosted: 18:41 - 01 Sep 2005    Post subject: Reply with quote
i started this yesturday! Made progress today started stripping the paint of the engine which someone probably spent ages doing but it doesnt look good!
Only done one coat so theres still paint left on which i will try to finish tomorrow.
Whats the best thing to scrape the paint off with, ive used a toothbrush for getting into little places.
ZRX61
Victor Meldrew
PostPosted: 19:52 - 01 Sep 2005    Post subject: Reply with quote
wire brush, steel wool, plastic scrapers etc, helps if ya cover the stripper with tin foil which stops it drying out so it works longer/better.
I have some really spiffy carbon/carbon scrapers made from the tail of an F117 that work quite well Smile
deputy
PostPosted: 15:29 - 02 Sep 2005    Post subject: Reply with quote
Only experience of Nitromors I have had was when a lad that I used to work with painted the interior walls of a portacabin with emulsion and got more paint on the floor than the walls. He then decided to clean the floor and poured Nitromors on the VINYL floor and used an industrial floor buffer to spread most of the floor all over the newly painted walls. Absolute classic.
DynaMight
PostPosted: 15:43 - 02 Sep 2005    Post subject: Reply with quote
Used it to take the paint off wheels and a swingarm, Works really well and has never needed more than 2 coats (although the 2nd coat is only applied to small areas)
The last post was made 21 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 70.5 Kb
