MTX 125
Philious
PostPosted: 00:28 - 31 Aug 2005    Post subject: MTX 125 Reply with quote
Hi just out of curiousity what oil do i put into the gearbox on this bike.
I need to give it a good service soon so any ideas for what might be good to do will be appreciated.
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
knockout_bar
PostPosted: 11:19 - 31 Aug 2005    Post subject: Reply with quote
Do you know what oil is in the gearbox now? If so, put the same stuff in next time.
If you don't know, drain it as much as you can and fill it up using ENGINE OIL. NOT two stroke oil.
If you're going for a service, change the spark plug. Make sure the oil tank is topped off (this should be with 2 stroke oil). Check the chain tension and wheel alignment. Check the brakes. Oil the control cables (just a little bit down the end of the clutch and brake cables (only if your front brake is drum)). Put chain lube on the chain (all the way round). Check that everything is secure in place i.e. no rattling bolts, cracked plastic. Check all the electronics are working, and listen out for unusual sounds.
125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) Thumbs Up
Paracaine
PostPosted: 12:37 - 31 Aug 2005    Post subject: Reply with quote
I wouldn't put engine oil in the gearbox, I would put gearbox oil in it.
I am afraid I don't know what grade oil your bike would take though.
Bike: Suzuki Bandit 600, 2002, Blue
Type: Unfaired
Extras: Datatool Alarm & Immobiliser, Airblade Tinted Fly Screen, Motrax Crash Protectors
knockout_bar
PostPosted: 12:49 - 31 Aug 2005    Post subject: Reply with quote
Where else does engine oil go? It doesn't go in the crank.
PostPosted: 20:51 - 31 Aug 2005    Post subject: Reply with quote
From the Honda workshop manual for the MBX125 (basically the same engine as the MTX125) the oil to use is "Honda Ultra-U 4-stroke oil or equivalent API service classification SE, 10W30".
The last post was made 21 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 45.12 Kb
