TL1000R - '98 - Starting Troubles
Raggaroo
PostPosted: 18:28 - 30 Aug 2005    Post subject: TL1000R - '98 - Starting Troubles Reply with quote
Hi,
I have a gorgeous 1998 TL1000R which I absolutely love - when it's on the road!
As I only use it at weekends, the battery often flattens easily. In nearly a year I'm now on it's 4th battery and unless I can find another solution I'll be buying a 5th next weekend!
I bought a trickle charger, but it doesn't work with sealed batteries!
I also have nothing to jump the bike from, I can't use the car for fear of cooking something!
Today when I tried to start the bike, it didn't even tick over or try to start, it just made a clicking sound - it this the starter motor and if so what can I do to stop this and make the bike start?
I will disconnect the Datatool, but any other ideas or do I have to buy another battery?
RaGgArOo
no_shad
PostPosted: 20:40 - 30 Aug 2005    Post subject: Reply with quote
Buy an optimate or similar. Thumbs Up
Raggaroo
PostPosted: 19:26 - 31 Aug 2005    Post subject: Reply with quote
Thanks No_shad
Just bought an Oxford Maximiser, hopefully that'll do the trick!
RaGgArOo
the grim reaper
PostPosted: 13:33 - 01 Sep 2005    Post subject: Reply with quote
I take it that you have checked the reg/rec to make sure it's charging the battery? If your batteries are dying that quickly, my bet is that the reg/rec is dead and is frying the battery with 16V or more when you rev the engine. Get a multimeter across the battery terminals and see what the voltage goes up to as you rev the engine. If it's above 14.5V you have a reg/rec issue.
As far as jump starting goes, use the car battery but WITHOUT THE ENGINE RUNNING. The car alternator can fry a bike CDI unit but the battery alone will turn it over just fine.
Grim
The last post was made 21 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 39.13 Kb
