Quick question !!!!!!!!
TOM M
PostPosted: 12:06 - 02 Sep 2005    Post subject: Quick question !!!!!!!! Reply with quote
How do i soften up the suspension on my zxr 400 as its way too hard.
The front end is fine, its the rear that needs softening up???????
Ive also noticed that it seems to use a lot of fuel, is this standard with the zxr's or could there be a problem somewhere?
Now owner of a 1200 Bandit
craigs23
Mr Muscle
PostPosted: 12:45 - 02 Sep 2005    Post subject: Reply with quote
ZXRs are notorious for their rock hard rear shocks aren't they?
Maybe slacken off the preload somewhat, but wouldn't want to compromise static sag (might make the bike wallow/drag its arse around/slow the rate of turn in).
Not sure on ZXRs, but the preload may be a collar type or lock nut/adjuster. Either way, you'll need to get a C-spanner on it. Turn it anti clockwise to reduce preload, clockwise to increase.
An aluminium drift or similar may help if a c-spanner isn't available.
PostPosted: 13:03 - 02 Sep 2005    Post subject: Reply with quote
Not sure if they are still available but I think NWS used to sell a replacement linkage part to change the ratios and soften the back end.
riichy
PostPosted: 15:03 - 02 Sep 2005    Post subject: Reply with quote
_city21"""" mine uses sh#t loads of fuel too, and mines restricted i just grin and bear it. Thumbs Up Neutral
.......... PLOD ............ zx636 2004
TOM M
PostPosted: 19:17 - 02 Sep 2005    Post subject: Reply with quote
So if i leave the shock as it is, will it cause any damage to it when taking pillions???????
PostPosted: 00:20 - 03 Sep 2005    Post subject: Reply with quote
No damge to the shock. The same can probably not be said for the pillions posterior.
Jrod
Page 3 Girl
PostPosted: 02:38 - 03 Sep 2005    Post subject: Reply with quote
You will want to upgrade your rear shock to solve the problem, my shock is nice and soft now and with my progressive fork springs it handles well.
The last post was made 20 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 52.35 Kb
