M10 fine 4" hex headed screw
froggy128
PostPosted: 10:06 - 02 Sep 2005    Post subject: M10 fine 4" hex headed screw Reply with quote
Where would i be able to get the above ive tried halfords wiches and some other places like that and they only have M10 c but am needing M10 fine for the bike
thanks
spitfire
PostPosted: 10:30 - 02 Sep 2005    Post subject: Reply with quote
https://www.namrick.co.uk/browse.asp?PCID=9
https://www.easywebstore.co.uk/stigfasteners/contentcollectionpage~Type~2~Category~3521.aspx
https://www.tastynuts.com/acatalog/index.html?http%3A//www.tastynuts.com/acatalog/TITANIUM_shop.html&CatalogBody
or look in your yellow pages for a hardware or tool store
HTH
PostPosted: 10:55 - 02 Sep 2005    Post subject: Reply with quote
Metric fine bolts are not easy to find. You can hopefully find them from a decent fastener supplier, but if not you might be reduced to buying an OE part from the bikes maker.
Oh, and asking for a metric bolt with an imperial length might amuse them.
PostPosted: 12:44 - 02 Sep 2005    Post subject: Reply with quote
Metal wholesalers often have a shop counter that sells odd fastners. I got to a big place in Carlisle called Thomas Grahams, providing you know what you want, they don't object to selling small quantities as they are aware that they are the only place that does them.
I dunno about the imperial/metric thing. A lot of engineers I know freely mix the two. If they learned imperial, they use it for everything except when unavoidable (such as a metric thread). If they were making the bolt on a lathe, they would measure their bit of hex bar in inches then cut a metric thread on it without blinking. (although a mate of mine got irrationally upset when another mate asked him to make a set of studs for his BSA chop with cycle-thread on one side and metric on the other so he could use easily available nuts when they rattled off.)
PostPosted: 13:03 - 02 Sep 2005    Post subject: Reply with quote
It is the fine pitch that might be a problem.
PostPosted: 13:16 - 02 Sep 2005    Post subject: Reply with quote
Aye, that is usually what I go there for. I've bought calliper bolts and the big f-off nut that held the clutch basket on my Jawa from there in the past. Also brass nuts the other weekend.
PostPosted: 13:23 - 02 Sep 2005    Post subject: Reply with quote
Took me ages to find some for the Bandit. Could not find a local supplier.
The last post was made 21 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 54.55 Kb
