Does this clutch count as "notched"? (pics)
loply
PostPosted: 18:52 - 02 Sep 2005    Post subject: Does this clutch count as "notched"? (pics) Reply with quote
Hi folks,
I've had continous problems with my clutch being incredibly grabby, and with it "jerking" whilst slipping since I replaced the clutch boss and plates a while ago.
I replaced the boss (pictured) with a second hand one as mine was broken by a previous owner.
As you can see there are a few small notches but I dont know if they are bad enough to be the cause of the problem, as Im sure my previous boss was even worse (and that was perfectly fine).
Does anybody with a more experienced eye know if this notching looks bad enough to cause jerkiness? The lever is smooth but the resultant acceleration kicks in with a bang and sometimes makes a repeated jerk/slip/jerk/slip motion.
I've tried running a steel back and forth on the boss by hand, and it felt smooth - The notches didnt feel like they were interfering.
If this isnt the problem, anybody know what else it could be? :S
https://home.loply.com/notches.jpg
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 20:55 - 02 Sep 2005    Post subject: Reply with quote
What does the slipper plate look like that sits adjacent to those marks? Couldn't help noticing that they all seem to be assosciated with the one (inside) plate and wondering if there is something wrong with it.
I have seen far worse clutches.
loply
PostPosted: 23:52 - 02 Sep 2005    Post subject: Reply with quote
Stinkwheel, there is a "spring" that sits inside the inner diameter of the second friction plate, called the cushion spring, which has caused the notches. I have replaced it but I dont believe it was damaged in any way, and removing it from the clutch all together made no difference.
PostPosted: 10:47 - 03 Sep 2005    Post subject: Reply with quote
I can't see that being your problem anyway. I have had clutches with 1/8" notches in the basket next to every plate before they started letting go.
I suppose other things to look at are warped plates, knackered cable (they sometimes start unravelling in the outer) or even something wrong with the mechanism for seperating the plates such as a bent pin. On some bikes the rod that goes through the engine to press the plates apart is in two halves with a single ball bearing betwen the two, this could be missing I suppose (easily lost).
Test things for straightness by rolling/placing them on a sheet of glass and seing if they rock about.
Also have a look at stuff like the chain tension and check the bearings the clutch sits on for play.
The last post was made 20 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 41.36 Kb
