| riichy |
 riichy World Chat Champion
 Posted: 01:25 - 07 Sep 2005 Post subject: any idears |
ok on my zxr400 a fex fairing blots have rusted shut, so i put some WD40 on them then found out that the person who had it befor me had rounded the blots off , so now the alen key just spins in the grove... any one know how i might get then off so i can fit some new ones  ____________________ .......... PLOD ............ zx636 2004 |
| riichy |
| mr.z |
 mr.z World Chat Champion
 Posted: 01:51 - 07 Sep 2005 Post subject: |
get a lightly biger alan key imperial would do) and try that, or use a screwdriver that fits the gap...
OR use a dremel to cut a slot in the top...
Use some copper slip next time! ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| MADDOG |
 MADDOG Borekit Bruiser
| riichy |
 Posted: 12:08 - 07 Sep 2005 Post subject: |
| 0ddball |
 0ddball World Chat Champion
| tribal_tiger |
 tribal_tiger World Chat Champion
| Teaman |
 Teaman World Chat Champion
 Posted: 17:29 - 08 Sep 2005 Post subject: |
| stinkwheel wrote: | You might be easier to just drill the heads off them and undo the stump with a pair of mole grips or by cutting a slot in it after the plastics are off. |
i have to agree, i spend a fair ammount of my day removing screws, broken taps from 2mm to 8mm and to be honest you dont want to be using stud extraction tools on anything smaller than an m10+ if its siezed,,, it just wont work, there not made for that.
drill carefully through the center of the head and do what stick wheel says or use torx bits,, they grip most allan heads , also you can hit em in if the bolts ally,,, ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
 Posted: 18:56 - 08 Sep 2005 Post subject: |
If it is an alloy bolt then you can drill the head off very easily. Steel are a bit more difficult and remember that as you drill the steel it gets hot, certainly hot enough to start to melt the plastic. Not a problem as long as you are careful and give it time to cool down as you go.
Eazi outs are not likely to be much use for a fairing bolt, added to which they have a habit of snapping off and are a nightmare to drill out.
| kb-zxr |
 kb-zxr Could Be A Chat Bot
The last post was made 21 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
