Slipper Clutch?
The Dude
PostPosted: 02:49 - 07 Sep 2005    Post subject: Slipper Clutch? Reply with quote
Hi all. Could someone explain to me in basic English what exactly is the difference between a normal clutch and a slipper clutch please? What difference would it make going up and down gears? I've look on a few sites but it all gets a bit technical for me after a few sentences.lol. Cheers Smile
Rookie
PostPosted: 03:08 - 07 Sep 2005    Post subject: Reply with quote
When you downshift the back wheel can lock up which, obviously is a bad thing. So to stop this happening, a slipper clutch 'slips' the clutch when the rear wheel is under strain, to counter this.
Effectively it's more stable for gearing down quickly.
The Dude
PostPosted: 03:12 - 07 Sep 2005    Post subject: Reply with quote
Ah. So it stops engine braking to a certain extent? A bit more like a 2 stroke?
sickpup
Old Timer
PostPosted: 09:59 - 07 Sep 2005    Post subject: Reply with quote
Yiou know the freewheel on the back wheel of a pushbike, the thing with the sprockets? thats what a slipper clutch does, only works in one direction so reverse torque cant lock therer wheel.
John C
PostPosted: 10:37 - 07 Sep 2005    Post subject: Reply with quote
At a guess I'd say it works in both directions, so you still get engine braking, but after x amount of reverse torque the clutch will slip instead of the wheel locking up?
DucatiEVO
PostPosted: 11:15 - 07 Sep 2005    Post subject: Reply with quote
I think the slipper only works in one direction (if it worked in both directions wouldn't it slip on a fast pull away?).
I have one on my Duc, and inside the section that the center rises on is aimed in one direction only. I assume so it will only work a certain way.
Very handy on a twin, as they are prone to luckup on downshifting.
Smile
aKa: Ducky
John C
PostPosted: 11:28 - 07 Sep 2005    Post subject: Reply with quote
Yes, I think your right, only slips in one direction. I was referring to the non-slippage (so to speak). As in forwards it won't slip, and when you change down it won't slip, unless torque x is exceeded.
If it was like a pushbikes back wheel (as said above) you would have no engine braking at all!!
DucatiEVO
PostPosted: 11:32 - 07 Sep 2005    Post subject: Reply with quote
Very Happy I hate trying to type something technical, always comes out as gobbley gook, and always has 'typos'. *lol*
aKa: Ducky
John C
PostPosted: 11:57 - 07 Sep 2005    Post subject: Reply with quote
I finds thaat tooo, dambn typods Thumbs Up
Mr C
PostPosted: 19:52 - 07 Sep 2005    Post subject: Reply with quote
A slipper clutch basically releases when the rear wheel speed is in excess of the engine speed, or when the rear wheel is trying to drive the engine rather than the other way around - ie under haeavy engine braking - it does it with a series of balls in tracks which are flung outwards and work against the clutch springs to release the pack a bit as the clutch speeds up - that's a crap explanation but it's something like that
it doesn't work in the opposite direction as the clutch is never faster than the rear wheel when accelerating - if you know what I mean
the opposite is a lock-up clutch which has weights on arms on it which run against the inside of the clutch cover so that the faster it spins the more it presses the pack together
useful for massive power applications like turbos
187.3bhp = 201mph
kb-zxr
PostPosted: 20:38 - 07 Sep 2005    Post subject: Reply with quote
If that was intentional that was funny Smile Mr. Green
Yoshi
PostPosted: 21:07 - 07 Sep 2005    Post subject: Lol Reply with quote
Well I downshifted too many gears before letting the clutch out whilst slowing down to turn off a road the other day and i think the back wheel locked up or something or at least it felt like it. I pulled in the clutch, changed up and all was well, but it seems that if I hadn't pulled in the clutch quickly enough then I could have come off, if this what the slipper clutches prevent?
Because that is a good idea if it is! Thumbs Up
Matt Cool
Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250
John C
PostPosted: 11:43 - 08 Sep 2005    Post subject: Reply with quote
Thanks Thumbs Up , it was intentional, and there's plenty more where that came from. Mr. Green
NSR125-Kid-UK
Attention Whore
PostPosted: 13:08 - 08 Sep 2005    Post subject: Reply with quote
The invasion of the typods!!!
"Arrrgh run the typods are attacking! with their typod tripods!!" Razz
Razz <---is it just me, or does this smily look deranged rather thanb just sticking his tongue out.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
John C
PostPosted: 16:36 - 08 Sep 2005    Post subject: Reply with quote
Razz Looks more like Kojak Razz
The last post was made 21 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 85.32 Kb
