| mistergixer |
 mistergixer World Chat Champion
 Posted: 20:17 - 06 Sep 2005 Post subject: Running in. |
I'm shortly to buy a brand spanking new K5 Gixer 750 (obviously in blue/white - they go quicker).
Heard conflicting advice on the subject of running engines in, do i adhere to the manufacturers advice of low revs etc etc or should i ride it normally from new? I've heard that an engine used normally from new will produce more power than a 'properly' run in engine.
Any ideas? ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
 Posted: 22:07 - 06 Sep 2005 Post subject: |
I doubt the manufacturer would recommend riding at low revs these days, just as likley to damage your engine. I would be riding it cautiously. By that I mean not having the engine labouring for the first 500 miles or so. Doesn't mean you can't go fast, just not thrashing it.
What you are thinking of is the practice of riding a new engine hard from brand new. As I recall you warm it up thoroughly then go out for a good blast on it for a relatively short distance (no more than 100 miles), working the engine right through the rev range. That or give it a dyno run. You then immediately change the oil and filter and it is considered run-in.
It is a proven point that engines treated like this generate more power after a few thousand miles than a conventionally run in one. This is because the piston rings seal better due to having been worked hard against the honing on the new barrel.
I still have my doubts as to how this would affect long-term reliability in an engine with shell bearings and hardened valve guides.
The jury is still out. It occurred to me that if you were serious about this kind of thing, you could run it in conventionally then fit new rings and give the barrels a hone before taking it for the thrash/oil change protocol. Seems a lot of work, but frankly, if you are going to need/use the extra horsepower, stripping the top-end of an engine is not going to be a big issue for you (we are not talking large numbers of ponies).
I am sure there will be many, differing oppinions. If it were my bike, I would go for the 'not thrashing the nuts off it for the first 500 miles' regime. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mistergixer |
 Posted: 22:15 - 06 Sep 2005 Post subject: |
Personally the thrash it from new regime seems lacking in mechanical sympathy to me. ____________________ Space Monkey #7
| McGee |
 McGee O RLY?
 Posted: 22:16 - 06 Sep 2005 Post subject: |
Dont go straight balls out on the throttle keep it steady for first 200 miles i say then its up to you. also try to change the oil more often than what the manufacturer does it helps, well i think it does. ____________________ ◙◙► K6 GSXR 600 ◄◙◙◙◙► K5 GSXR 1000 ◄◙◙◙◙► K5 GSXR 600 ◄◙◙◙◙► 96 RF600r ◄◙◙
Its pronounced Jixxer! |
| sickpup |
 sickpup Old Timer
| Robby |
 Robby Dirty Old Man
| 0ddball |
 0ddball World Chat Champion
The last post was made 21 years, 53 days ago. Instead of replying here, would creating a new thread be more useful? |
