what panel lights do I need?
gimpy limp
PostPosted: 13:25 - 13 Sep 2005    Post subject: what panel lights do I need? Reply with quote
What do I need for the mot - indicator lights, high beam light.
do i need a neutral light? Anything else? Is their a light for dipped beam I need?
I'm going to have to buy led lights of some sort and mount and wire them in as panel lights for those things above.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
PostPosted: 22:28 - 13 Sep 2005    Post subject: Reply with quote
You need a high beam light.
You need a flasher repeater light UNLESS you can see the indicators from the seated position. Some bikes used to have a small hole drilled in the top of the front flashers with a piece of coloured glass in it for this very purpose.
You need a speedo back light.
You do not need a Neutral light, an oil pressure warning light or a battery charging warning light for the MOT but they are useful. If they are fitted, they should work.
mistergixer
PostPosted: 23:11 - 13 Sep 2005    Post subject: Reply with quote
I thought it was just headlamps etc, not idiot lights.
https://www.vosa.gov.uk/vosa/publications/your%20motor%20bike%20and%20the%20mot.pdf
Space Monkey #7
Jack_Cheese
PostPosted: 23:15 - 13 Sep 2005    Post subject: Reply with quote
register it for day use and sod the lights!
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
instigator
PostPosted: 23:16 - 13 Sep 2005    Post subject: Reply with quote
Do you need a dipped light?
gimpy limp
PostPosted: 23:20 - 13 Sep 2005    Post subject: Reply with quote
Didn't cross my mind that one, i'll have to mount something on the top like a licence plate light maybe.
PostPosted: 02:02 - 14 Sep 2005    Post subject: Reply with quote
If you want to keep things as uncluttered as possible. You can fit a hidden buzzer/beeper in place of a flasher repeater light. The 'tell-tale' can be audio as well as visual.
The last post was made 21 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 53.14 Kb
