| whelleyman |
 whelleyman L Plate Warrior
| knockout_bar |
 knockout_bar Scooby Slapper
 Posted: 22:19 - 11 Sep 2005 Post subject: |
You'll need to fit a smaller rear sprocket, but you'll loose acceleration by doing this. ____________________ 125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee)  |
| Biker-Kev |
 Biker-Kev Brolly Dolly
 Posted: 23:16 - 11 Sep 2005 Post subject: |
There is a restrictor in the carb! ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license |
| alains |
 alains World Chat Champion
| Biker-Kev |
 Posted: 00:28 - 12 Sep 2005 Post subject: |
https://www.nsr125.com/derestrict.htm
alians- i cannot find the website which told of the restrictor in the carb, which was in the form of a small metal plate, but if i come across it again i will be sure to post it!
If you know there is not a restrictor here, you oubviously know where they are so help the guy out!
Kev ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
| alains |
| knockout_bar |
 Posted: 13:58 - 12 Sep 2005 Post subject: |
Taking the restricter out of the carb will not increase your top speed!!!!!!!!!!! You NEED to fit a smaller rear sprockt (or a bigger front sprocket). ____________________ 125 trail bike, custom bars, handguards etc. - ?500.
| OreoXX |
 OreoXX Nova Slayer
| trafficdodger |
 trafficdodger Scooby Slapper
| OreoXX |
 OreoXX Nova Slayer
| trafficdodger |
| ayfy |
 ayfy Nova Slayer
| alains |
 Posted: 19:59 - 13 Sep 2005 Post subject: |
order your jets first at https://www.dellorto.co.uk (about £3 each)
then you need to take the carb off :
- take off tank (1 bolt + fuel pipe) mind the rubbers on each side
- take off air box (2 screws , 1 collar between carb & air box and a pipe in front underneath)
- undo all pipes coming out of the carb , lift up the oil feedind pipe and let it up (avoiding oil leak)
- undo the screw on top of the choke et take it out
- undo the 2 screws on top of the throttle and take it out
- untighten the collar screw and now the carb is your's
to dismantle the carb :
- under the float chamber , in the middle , undo the bolt , the float chamber will separate
- the main jet is in the middle of this bolt
- the slow jet has same dimensions as the main jet
- the powerjet is much smaller than the others
- by the way clean the fuel strainer
- pay attention at the float valve ____________________ the worst day fishing is better than the best day working |
| OreoXX |
 OreoXX Nova Slayer
| alains |
 Posted: 14:24 - 14 Sep 2005 Post subject: |
you've got everything right , do not worry . now you will feel the difference , providing you had clean the foam in the air box and re-set your pilot screw (about undoing 1/4 to 1/2 round more than previously)
after the next 100 miles , check your plug colour here
https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html ____________________ the worst day fishing is better than the best day working |
| OreoXX |
 OreoXX Nova Slayer
 Posted: 14:28 - 14 Sep 2005 Post subject: |
I fitted the 10EIX spark plug, and I have ridden for a while and checked it occasionally, it seems fine! the pilot screw also seems to be set fine, and the idle RPM is at 1400 +- 150 (appr.) My sprockets are standard sizes and I'm not considering replacing them either, the bike is fast enough!  |
| alains |
| OreoXX |
 OreoXX Nova Slayer
 Posted: 14:45 - 14 Sep 2005 Post subject: |
I have 36 on the rear, and I'm pretty sure the front is 13, I don't know if it is a 13 or a 14. If mine is 13, and I fit a 14, will I lose a lot of acceleration? Im not an expert on the topic  |
| alains |
| OreoXX |
 OreoXX Nova Slayer
| alains |
 Posted: 16:20 - 14 Sep 2005 Post subject: |
ok now , i think you have a nsr before 1993 . so the genuine sprockets are 13x35 . if you are not near the end with your sprockets , just buy a 14 and change it (see JT they are UK made) and when your chain will be worn (or your rear) buy a 14x36
here is the link (all sprockets are the same) :
https://www.jtsprockets.com/52.0.html?&L=0&sel_uid=151&p= ____________________ the worst day fishing is better than the best day working |
| OreoXX |
 OreoXX Nova Slayer
 Posted: 22:38 - 14 Sep 2005 Post subject: |
No my NSR is a 2001 model, but it had an owner before I bought it, maybe he changed the sprockets, I'm not sure. Anyways, I will buy a 14x36 set, since my sprockets are badly worn already and the chain is at the replacement mark
Will this make any difference if my sprockets are 13x35 now? |
| alains |
| kenny |
 kenny Nearly there...
| alains |
The last post was made 21 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
