Mixing Oils
black gpz500s
PostPosted: 20:07 - 19 Sep 2005    Post subject: Mixing Oils Reply with quote
I'm about to do an oil change on my bike (900 Fireblade). I've done about 4000 miles on it since buying it secondhand.
I haven't topped up the oil since I've had the bike because I don't know what type of oil is currently in it. I've been warned that mixing mineral oil and synthetic oil is dangerous, and this is why I want to drain the existing oil and start anew.
Once I have drained the old oil from the engine, there will still be small amounts left inside, clinging to components etc. Would these remaining traces of old oil, when mixed with a new oil, cause a problem if one were mineral and one synthetic?
Thanks.
Teaman
PostPosted: 20:11 - 19 Sep 2005    Post subject: Reply with quote
mixing synth with non synth will turn it to porrage, very very bad,,
your bike will have semi syth in it as most jap bikes do,,
if your in doubt buy a flush oil,
its a pain in the arse tbh and ive never done it,,
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Ichy
PostPosted: 21:44 - 19 Sep 2005    Post subject: Reply with quote
So how does a semi synth react to a full synth?
GearboxGeezer
PostPosted: 21:48 - 19 Sep 2005    Post subject: Reply with quote
reacts good, should be no problems, but don't just take my advise as im only %90 sure.
Teaman
PostPosted: 21:51 - 19 Sep 2005    Post subject: Reply with quote
safest bet at a guess, not many bikes use mineral nowadays anyway, havnt for donkeys years
PostPosted: 21:53 - 19 Sep 2005    Post subject: Reply with quote
If a previous owner put mineral oil in a FireBlade then he should be shot.
If I were you, I'd buy an oil filter and change the oil. You won't need to flush the engine, but I'd put a good quality semi synthetic or fully synthetic motorcycle oil in there, something like Castrol, Rock Oil, Mobil... something you have heard of. Make sure you use the correct grade though, I expect it will be 10w40, but I was surprised to find that 15w50 was reccomended for my TT600.
I would advise against using car oil, as they have stuff in them that can upset your clutch. I know Keith (Kickstart) uses car oil in his Bandit, but I also know that McJams old ZX6R reacted badly to car oil at some point in its life (I can't remember wether G, Ste or McJam was the owner at the time... Smile ). Basically it made the clutch slip.
Most places seem to reccomend the use of fully synth in a superbike such as a blade, but as Teaman said 99% of japanese bikes use semi synth so I guess there isn't *that* much difference.
The main thing is not to use £1 per litre tescos oil in there... Smile
Robby
Dirty Old Man
PostPosted: 22:20 - 19 Sep 2005    Post subject: Reply with quote
Right, clear the bullshit first.
Mineral and synthetic oils do not react when mixed. A synthetic oil is just a mineral oil with a different additive pack. You can't mix vegetable and mineral oils, but we are not dealing with vegetable oils here.
Do as MarJay said for the oilchange. The small bits of residual oil are not a problem. Flushing oil is not needed unless its really shitty in there, and even then I'd be inclined to do an oil change and then do another one in 500 miles.
Teaman
PostPosted: 08:22 - 21 Sep 2005    Post subject: Reply with quote
If you've been driving around with mineral oil in your engine for years, don't switch to synthetic oil without preparation. Synthetic oils have been known to dislodge the baked-on deposits from mineral oils and leave them floating around your engine - not good. I learned this lesson the hard way! It's wise to use a flushing oil first.
If you do decide to change, only go up the scale. If you've been running around on synthetic, don't change down to a mineral-based oil - your engine might not be able to cope with the degradation in lubrication. Consequently, if you've been using mineral oil, try a semi or a full synthetic oil. By degradation, I'm speaking of the wear tolerances that an engine develops based on the oil that it's using. Thicker mineral oils mean thicker layers of oil coating the moving parts (by microns though). Switching to a thinner synthetic oil can cause piston rings to leak and in some very rare cases, piston slap or crank vibration.
Gaskets and seals! With the makeup of synthetic oils being different from mineral oils, mineral-oil-soaked gaskets and seals have been known to leak when exposed to synthetic oils. Perhaps not that common an occurrence, but worth bearing in mind nevertheless.
this info i got from
https://www.chris-longhurst.com/carbibles/engineoil_bible.html
I thought I'd check it up. as ive been flagged for my first comment
Jack_Cheese
PostPosted: 09:58 - 21 Sep 2005    Post subject: Reply with quote
I think the gunking only occurs is 2-strokes with non-synthetic and fully synethic mixtures because of the oil being burned. I know of one scooter owner this has definitely happened to. Whether other factors are involved in this gunking up is a mystery to me. If i were you, i'd just use honda's recomended oil, but that's only because i'd be overly paranoid of buggering something up because i'm a bit of a numpty when it comes to mechanics...
jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
The last post was made 21 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 63.31 Kb
