URGENT - exhaust is loose from back of bike
dansuresh
PostPosted: 19:23 - 20 Sep 2005    Post subject: URGENT - exhaust is loose from back of bike Reply with quote
Hey
My exhaust has somehow broke off the back of the bike where it attaches just below the pillion pegs...
I got some pics below
i need to get it fixed somehow to the bike so it doesnt cause anymore damage and i need the bike for getting to school and work!
anyone know how to bodge this one? Sad
i was thinking of string or something but its going to have to be something that is heat proof
thanks
Dan
'S' Derbi GPR50R ------> 'Y' Aprilia RS125 -------> '04' SV650S K4 -------> 'Y' Honda CBR600 F Sport
Paracaine
PostPosted: 19:29 - 20 Sep 2005    Post subject: Reply with quote
Can you take a better photo from more of a side on view?
Bike: Suzuki Bandit 600, 2002, Blue
Type: Unfaired
Extras: Datatool Alarm & Immobiliser, Airblade Tinted Fly Screen, Motrax Crash Protectors
palmer
Fiddled Kiddy
PostPosted: 19:33 - 20 Sep 2005    Post subject: Reply with quote
looks like you've snapped the bolt. just put another one through.
dansuresh
PostPosted: 19:34 - 20 Sep 2005    Post subject: Reply with quote
yeah will do...
u mean frm the same position the exhaust is pointing?
dansuresh
PostPosted: 19:35 - 20 Sep 2005    Post subject: Reply with quote
yeah the bolt did look snapped but is there anything that i can do with it until the weekend or will it be ok to leave it as is and ride slower?
really dont want it causing anymore damage..
Dan
jamie192
PostPosted: 19:44 - 20 Sep 2005    Post subject: Reply with quote
Maybe you could use string to bodge it, but if you can get the bolt out, put some wire through the hole where the bolt would normally go, and twist it untill its tight, and get down hursts at the first available opportunity.
Ride Fast, Brake hard, don't fall off!
dansuresh
PostPosted: 19:45 - 20 Sep 2005    Post subject: Reply with quote
heres some better photos
Ichy
PostPosted: 19:56 - 20 Sep 2005    Post subject: Reply with quote
For a bodge I would either try to get a jubilee clip around it under the bolt and nut, or use some decent wire (something like they use for wire fences).
Sometimes a good hit with a center punch on the remaining bit of bolt will knock the weld nut off, just replace with any old nut and bolt. same if you get a spanner on it and give it a good twist.
Drill the center out of the bolt and use a smaller nut and bolt until you can tap it out.
Not worth riding as it is, your either putting stress on the rest of the pipe or if its a slip on type of fit it might just fall off.
dave1rs
PostPosted: 20:02 - 20 Sep 2005    Post subject: Reply with quote
bah just ride it,standard rs exhaust wont break if unsupported.
you havent snapped the bolt,the mount is actually 2 bolts that meet in between the rubber piece,just remove the old broken bits and bolt it in place. Wink
dansuresh
PostPosted: 20:10 - 20 Sep 2005    Post subject: Reply with quote
what do you mean by bolt it in place??
the rubber spacer thing seems to have split, so do i just need to replace that thing then?
Nothing seems to be broken its just the rubber thing, i assumed the bolt snaped cos it was in two pieces!
Thanks
Dan
fast_tzr
PostPosted: 20:14 - 20 Sep 2005    Post subject: Reply with quote
just get the bolt out, and loop a ziptie through the bolthole and and the exhaust hanger hole.(soz for shitty explanation)
dave1rs
PostPosted: 20:17 - 20 Sep 2005    Post subject: Reply with quote
Thanks
Dan
i mean just loosely bolt the exhaust to the hanger,dont do it up tight as the exhaust needs some movement...will be fine till you can get the new rubber part...which incidentally comes with the bolts mounted in place.
The last post was made 21 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 72.86 Kb
