Fitting New Chain
kb-zxr
PostPosted: 20:24 - 20 Sep 2005    Post subject: Fitting New Chain Reply with quote
I just ordered a new chain, is it possible to fit safely without specilist tools?
Thanks, Kurt
beast rider
PostPosted: 20:26 - 20 Sep 2005    Post subject: Reply with quote
You need a chain splitter/riviter.
kb-zxr
PostPosted: 10:43 - 21 Sep 2005    Post subject: Reply with quote
Thanks for that, I think I can get hold of one today.
A couple more questions -
1. Is there a certain way round the chain has to go on, or doesnt it matter?
2. Is there anything else I have to make sure of/do or something to watch when I do it. I have already fitted the new sprokets, and know I have to tighten the chain when I put it on.
Thanks, Kurt
beast rider
PostPosted: 15:18 - 21 Sep 2005    Post subject: Reply with quote
It doesn't matter what way round the chain goes! the only other thing is make sure you rivet the chain properly and give it a good lubing once your done.
Mr.Everready
PostPosted: 15:29 - 21 Sep 2005    Post subject: Reply with quote
If you've got a riveter fitting the chain is very very easy, 10 minutes and you'll be done.
Nath
PostPosted: 15:41 - 21 Sep 2005    Post subject: Reply with quote
Your chain should come pre-lubricated. And it will probably slacken off a bit quite quickly before settling down
Hard livin', hard luck.
kb-zxr
PostPosted: 16:05 - 21 Sep 2005    Post subject: Reply with quote
Thanks for all the help people. The chain is pre lubed but when I put it on I will give it a damn good seeing to with some more chain lube Smile
I'll check it and adjust it every few miles too.
Kurt
quik_d
PostPosted: 00:10 - 22 Sep 2005    Post subject: Reply with quote
dont most chains come with a removable link and a split pin? so not rivetting is needed? No?
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
Mr.Everready
PostPosted: 14:28 - 22 Sep 2005    Post subject: Reply with quote
Most (99%?) bigger bike chains need rivetting. It's stronger.
Davo
Davo To The Rescue!
PostPosted: 14:45 - 22 Sep 2005    Post subject: Reply with quote
My Hayabusa had this kind of chain, don't think you get much bigger.
Jrod
Page 3 Girl
PostPosted: 16:04 - 22 Sep 2005    Post subject: Reply with quote
Cut the old chain off with a hacksaw, put the new 1 on with a split link. Job done. Cool
The last post was made 21 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 65.57 Kb
