Sony net MD
Milo
PostPosted: 12:54 - 19 Feb 2003    Post subject: Sony net MD Reply with quote
anyone know much about these as i'm considering one at the mo.
I know it connects to the comp for quick music transfer (32x i think) and you can do this with MP3's but does it store the digitally on the MD or convert them to analogue and take up more space?
I don't think it's possible to get a MD writing at 32x so surely it must store and read them as digital music?
Surely if it stores them digitally I'll be able to have loads of music on a lil MD without all this MDLP compression stuff?
Thanks for any info in advance!
Milo
TiN
Pocket Tin
PostPosted: 13:02 - 19 Feb 2003    Post subject: Reply with quote
MDs are digital anyway (and so are CDs)...the data stored on MDs are highly compressed, and the MDLP format even more so.
They're not *that* expensive nowadays, but I mainly dub MDs for the player in the car, which is rather old and doesn't support MDLP so I really can't be arsed with it.
Go for it.
TiN
dotgems.net
Milo
PostPosted: 13:07 - 19 Feb 2003    Post subject: Reply with quote
I couldn't remember the right word so i used analogue.
I meant does it convert the MP3's to normal CD/MD audio or does it store them digitally? A 650 meg MP3 storage space would be quite handy! Maybe it'd even act like a mini hard drive? but maybe i'm expecting too much
andrew
Mister Road Rage
PostPosted: 13:10 - 19 Feb 2003    Post subject: Reply with quote
I know its in the sun but this review shows how good the new md recorders are
https://www.thesun.co.uk/section/0,,2001310000,00.html
personally i think md is the best audio format out there.
Milo
PostPosted: 13:20 - 19 Feb 2003    Post subject: Reply with quote
But do you know anything about the Net MD, where it can be connected to a comp and music downloaded to it?
I've always had them on my desirable list but never really had the cash going spare.
TiN
Pocket Tin
PostPosted: 13:23 - 19 Feb 2003    Post subject: Reply with quote
Sony did produce an MD-based removable storage device once, but scrapped it soon afer it was released (it was expensive and the special MDs could only contain about 200meg of data). Sony use their own file-format and encoding method (ATRAC?) which is often better quality than MP3 and a smaller file size too.
TiN
dotgems.net
Milo
Yeah, it is ATRAC i think. Their software converts MP3 and others to this.
Why did it need special discs and recorder? Surely it'd just be a case of new hardware/firmware to write the data but the writer itself would be the same?
I can't get to that link cos my IT dept have blocked it?!
any chance someone could copy the main text and plonk it into a text document for me?
TiN
Pocket Tin
PostPosted: 13:24 - 19 Feb 2003    Post subject: Reply with quote
I think that they connect via the USB port, and you basically either rip directly from a CD, or drag some MP3s to be converted (or "optimised" as Sony call it) and then transferred to the MD.
TiN
dotgems.net
Milo
PostPosted: 13:27 - 19 Feb 2003    Post subject: Reply with quote
eek, maybe it's just me in a rush here at work.
How much music can it store in this digital (ATRAC?) format? is it more than normal audio in the normal mode?
TiN
Pocket Tin
PostPosted: 13:36 - 19 Feb 2003    Post subject: Reply with quote
A normal MD should store the same amount (time-wise) as a normal CD, and I think that's how ATRAC works - the compression algorithm is based on the length of the sample, rather than the original file-size.
As for "why the special MDs"...well, as I've said, the music is squeezed onto an MD, rather than just "put" on there, and it's a lot easier to compress a stream of data reliably than chunks of data. So, in order to store data (files, programs etc), the structure of the MD (i.e. the underside that is "burnt") needs to be completely different - the data is not compressed.
There is/was also an MD camcorder, which I followed (and drooled over) for a little while, but the fact that each MD could only store about 10 mins of high-quality video was a bit crap!
TiN
dotgems.net
Milo
PostPosted: 14:03 - 19 Feb 2003    Post subject: Reply with quote
I thought ATRAC is only on the newer Net MD's and Sony digital players.
MD's use the same distance between grooves as CD's-measured this in physics once before. They hold the same amount of data as they are double sided.
TiN
Pocket Tin
PostPosted: 14:30 - 19 Feb 2003    Post subject: Reply with quote
Umm...no...
https://www.nimbus.ltd.uk/nte/format/md-mo.html
https://www.nimbus.ltd.uk/nte/format/cd.html
MDs only have a 140mb capacity for data, and AFAIK, they're not double-sided.
TiN
dotgems.net
Milo
PostPosted: 15:03 - 19 Feb 2003    Post subject: Reply with quote
Oh Embarassed
For years i've been thinking that they were, doh!
TiN
Pocket Tin
PostPosted: 15:13 - 19 Feb 2003    Post subject: Reply with quote
It's ok, but do you really think that MD recorders could be so cheap (relatively speaking) if they had dual lasers?
So are you gonna get one then?
TiN
dotgems.net
Milo
PostPosted: 15:18 - 19 Feb 2003    Post subject: Reply with quote
That's a good point, and i really should have guessed by the fact that there's no way there's a hidden, miniture laser in the lid of the thing!
I'll be getting one in a couple of months, i'll wait for the "revolutionary new" Net MD thing to get old, and maybe another company will bring something out like it.
Cheers for the info.
Ads
andrew
Mister Road Rage
Well if you had read that review i posted, using the new MZ-NF810 you can record various amounts of audio on a disk it depends on the compression you use, the bloke who reviewed that one managed to fit 5 hours of music on one disc which is very impressive, it also offeres *upto* 114 hours playback which i guess is using a combination of alkaline and lithium batteries. ATRAC (Adaptive Transform Acoustic Coding for MiniDisc) is the form of compression used to record data onto minidiscs, it has been used since the very beginning of mini discs but as time has gone on theyve improved it and released new versions which is what youll find on the newer players/recorders. Mini discs are not double sided as that would require 2 lasers, one below the disc and one above the disc, and they dont use the same method as cds for recording, they are magneto-optical based.
For more info on them go to
https://aroundcny.com/technofile/texts/minidiscidea93.html
https://www.minidisc.org/aes_atrac.html
Milo
PostPosted: 15:22 - 19 Feb 2003    Post subject: Reply with quote
Cheers mate, don't have time to read that review at work but i'll check it out when i get home.
skippy
PostPosted: 21:03 - 19 Feb 2003    Post subject: Reply with quote
I got a Sony Net MD - the MZ-N707
I download a lot my songs off Kazaa, or the others i just get off my CD's
Sony supply a program called Open MG-Jukebox with the player. All you gotta do is either browse through your PC files, and find the songs where you stored them, or select the drive u have put the CD into. It then converts the music files (in whatever format they are in - MP3, .wav etc) into ATRAC. It then records them onto normal minidiscs.
To record a 1 hour album into ATRAC and then onto the disc takes about 5 minutes or so.I record them on LP4, and the qualities fine, and i can store 3 - 4 albums on 1 disc.
Oh yea it connects through a USB port.
Probably repeated everything that has been said already, but im tired, and cant be assed to organise it all in my head Razz
Its all really easy to use, and i would recommend them Very Happy
Chris
Milo
PostPosted: 09:53 - 20 Feb 2003    Post subject: Reply with quote
Nice one, thanks mate.
I didn't realise that MD's could write that quick though!
Bhaal85
PostPosted: 22:27 - 23 Feb 2003    Post subject: Reply with quote
I am now gonna confuse things even more. They only transfer upto 32x if you have usb 2.0 posts, not the standard usb 1.0 ports. By the way, I am thinkin of sellin my md that supports mdlp 4. its a sony md mzn505.[/i]
Milo
PostPosted: 09:29 - 24 Feb 2003    Post subject: Reply with quote
Well my old motherboard'll prob only be USB 1 so it'll be a little slower.
Sorry mate, i was really after a net MD
TiN
Pocket Tin
PostPosted: 17:33 - 24 Feb 2003    Post subject: Reply with quote
I think the fastest that USB 1.0 can muster is 4 -6 speed Confused (that was the case with CD-writers anyway) but that's still faster than direct dubbing.
TiN
dotgems.net
Milo
PostPosted: 17:36 - 24 Feb 2003    Post subject: Reply with quote
I can live with 4-6, but as it'll be in ATRAC the amount of data transfered per audio second is less so it should be more like 12-20...i hope!
We'll find out when i get the thing.
or if i'm a speed freak i'm sure there's a PCI USB2 card out there for not too much money
Demonic69
The Pink Rhino
PostPosted: 17:38 - 24 Feb 2003    Post subject: Reply with quote
About £20 Very Happy
it'll still only bee 4x but you'll be sending less data
Back on a Blade. Just feels so right.
TiN
Pocket Tin
PostPosted: 17:39 - 24 Feb 2003    Post subject: Reply with quote
It's funny that you should mention that Smile ...'cos I've got a nearly-new (bought about a year ago, but not used) USB 2.0 card that I don't need...it's a Belkin and has 4 ports...
TiN
dotgems.net
The last post was made 23 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 125.74 Kb
