| froggy128 |
 froggy128 World Chat Champion
| eli_74 |
 eli_74 Nitrous Nuisance
| froggy128 |
 Posted: 17:20 - 23 Sep 2005 Post subject: |
you can get it from cmc  |
| dodsi |
 dodsi Dirty Carny
 Posted: 17:22 - 23 Sep 2005 Post subject: |
www.scottoiler.co.uk
£30 with free shipping for 5 litres, cheaper than shop prices.
wax polish your paint up, thats the best stuff to use, wax the frame etc aswell. stops shit sticking so well. |
| craigs23 |
 craigs23 Mr Muscle
| kb-zxr |
 kb-zxr Could Be A Chat Bot
| flat spot |
 flat spot World Chat Champion
| eli_74 |
 Posted: 22:22 - 23 Sep 2005 Post subject: |
| dodsi |
 dodsi Dirty Carny
| dransy |
 dransy World Chat Champion
 Posted: 22:27 - 23 Sep 2005 Post subject: |
You stole my sig bitch  ____________________ Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles |
| dransy |
well my old one  ____________________ Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles |
| dodsi |
 dodsi Dirty Carny
| extreme3d |
 extreme3d World Chat Champion
 Posted: 23:00 - 23 Sep 2005 Post subject: |
Lots of water, and I mean lots - it's ironic but the best way to stop corrosion is with lots of water so use a hose. Use car shampoo such as triplewax which has wax in it to wash the bike with. This will leave a film of wax over the paint, engine, frame etc. If you ride everyday YOU NEED TO DO THIS EVERY DAY PERIOD. If you don't it will rot plain and simple REGARDLESS of make (Yes even Honda).
https://img.photobucket.com/albums/v171/dodsi2000/771016.jpg
Once a week use fairly liquid. I don't care what people say about it being to harsh - bull sh*t. We are not talking about using it neat or in a pressure washer - just a squirt in a bucket of hot water and a sponge. Let the suds to the work by squeezing the sponge over difficult to reach areas so soap suds pour down into it. You will soon have the bike degreased/desalted including if you wish all the chain oil of the rear wheel and sprocket. (fairly liquid works wonders for stripping chain oil - *read below before you all jump on me for this*) Next and this is crucial - use car shampoo again, as yes the fairy liquid will strip off all wax from the paint.
Get a towel (i have a couple ragged ones for bike/car use only) and first dry the exhaust cans, downpipes and engine casings (to prevent spot marking). Then turn on the engine and let it idle whilst you dry the rest of the bike. The trick is to let the engine's heat dry the INSIDE of the bike. This is important as the bike will not dry off overnight in the garage during winter. It also gets water out of the HT leads etc.
Once the bike is dry then the paint will be protected and you are good to go next day. Once a weekend when you have more time then yes you can polish the paint work to make it gleam but there is little point as come monday you will just wash all the polish off again!!! Polish is more for summer when you need only wash once a week and need to protect the paint during the gap.
This may seem a lot, but once you get the hang of washing it need only take 5 minutes.
Now as for removing chain oil from the sprockets/wheel/chain. I find fairy liquid removes this muck in seconds as its an active degreaser. But you MUST oil the chain again after or it will rust. The best way for winter riding is to fit a scottoiler as the oil is water based and normal car shampoo will remove it no problem. The wax in it will provent rusting.
Finally as you have discovered spray the bike with Scottoilers FS365. This contains salt inhibitors and will neutralise and prevent the salt corroding the metal. It has one downside and that is dirt will stick to the oil making the bike look grubby. But as it's water based as soon as you hit it with the hose it all wash's off.
https://img.photobucket.com/albums/v171/dodsi2000/so_0040_45_2300_detail.jpg
There is no need to spray the whole bike as you will soon use it all up if you do. I concentrate on the following areas:
Front and Underside of the engine.
Exhaust Collector Box (where downpipes join together)
Rear shock.
Fork lowers - Use a paper towel soaked in the spray to avoid disks.
Radiator and/or oil cooler
Bottom of Yokes
Foot Pegs
It is also a good idea once a week to squirt some WD40 into all the handlebar switches as all this washing can mean water will start to enter them.
Hope this helps and are you coming on the ride out tommrrow froggy? |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
| mr.z |
 mr.z World Chat Champion
 Posted: 03:22 - 24 Sep 2005 Post subject: |
The easy lazy way...
Give your bike a good going over every two/three weeks, propper through clean with what you'd normaly use...
(when its dry) Then anything shiney, get wd40, spray away, exhaust (will stink + smoke a little when you start up again, just dont sit breathing the fumes!)
Plastics, dunno, you can get some sort of faring wax stuff, but its hardly difficult to wipe them down + they aren't going to rot off like chrome anyway...
Make sure everwhere that should have grease on (springs e.t.c.) has, then get on yer gloves and get a load on the underside of the swingarm and any particuarly exposed parts (get a rear hugger for your monoshock if this applys to your bike!)
Come summer you can just clean all the gunk off, it will look like crap through winter, the wd looses any shine you had got, the gunk will collect dirt (make sure to replace gunk reguarly) but when spring has sprung all your shiney bits will still be
(been doing this for the past couple of years and its worked great up to now)
*Tesco sell packs of 3 toothbrushes, very very cheap, worth geting for chains and other smaller fiddleyer bits  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Teaman |
 Teaman World Chat Champion
| extreme3d |
| mr.z |
| extreme3d |
| palmer |
 palmer Fiddled Kiddy
| extreme3d |
| bish777 |
 bish777 World Chat Champion
The last post was made 20 years, 356 days ago. Instead of replying here, would creating a new thread be more useful? |
