R6 GEARBOX PROBLEM?
V4
PostPosted: 18:27 - 25 Sep 2005    Post subject: R6 GEARBOX PROBLEM? Reply with quote
Im looking at buying a mates 2000 r6 cheap, he wheelies it like a bastard and his 2nd gear has gone twice now, how much is a new second gear likely to set me back? How much life can you expect?
Is this a common problem? cheers
Leon
stu_m
PostPosted: 19:18 - 25 Sep 2005    Post subject: Reply with quote
a gear is usually about £80
its the labour that costs
there easy to make if your a gear cutter like me Laughing Laughing
V4
PostPosted: 19:47 - 25 Sep 2005    Post subject: Reply with quote
Can you get any heavy duty aftermarket gears? And are you really a gear cutter? lol Laughing
LEON
stu_m
PostPosted: 19:53 - 25 Sep 2005    Post subject: Reply with quote
yes i am a gear cutter
it will cost you more to get a company to make you one as you pay for the time it takes and heat treat as well
its cheaper to buy OE as they make them by the thousands
Wooly R6
PostPosted: 16:19 - 26 Sep 2005    Post subject: Reply with quote
i wouldnt even think about buying it!!!! Rolling Eyes
PostPosted: 19:50 - 26 Sep 2005    Post subject: Reply with quote
Problem is not the gear, it is the engine strip / rebuild that will be required to fit it. Just the gear, gaskets and sundries (oil, coolant, etc) will be around £200 before you spend the time / pay the labour for doing the job.
feef
Energiser Bunny
PostPosted: 00:55 - 27 Sep 2005    Post subject: Reply with quote
but do you do any one-offs??
I'm planning on putting the YZF750 6 speed box in my spare thunderace engine, but 1st and 6th ratios are the same as the standard 1st and 5th ratios that come with the 'ace.
If I was to get a couple of gears custom made, and ran a higher sprocket ratio, it would give me more akin to the current gearing with a 6th, higfher gear which I would find useful when sat on the Mway, or when touring.
is it feasible to get a couple of gears custom made, or are we talking silly money?
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
tonyyzf
PostPosted: 08:27 - 27 Sep 2005    Post subject: Reply with quote
You'd be a lot cheaper just raising the size of your front sprocket by one tooth
craigT19
Jolly Green Giant
PostPosted: 10:43 - 27 Sep 2005    Post subject: Reply with quote
ive got an old r6 engine including gearbox from a 2000 R6 at work,
had to be replaced cos the owner had worn out al the selector forks, gears them selves are fine tho, ill take a look tomorrow and get back to you.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
PostPosted: 13:56 - 27 Sep 2005    Post subject: Reply with quote
It would probably be better to have a hunt through the Yamaha parts lists and find suitable standard gears. Basically the same engine is used on the FZ750, FZX750, FZ700, FZR1000, FZR1000 EXUP, FZR750, FZR750 OW01, YZF750, GTS1000, Thunderace and YZF750 / YZF750SP. Good chance that you can source a suitable couple of gears from one of those.
This guy might be worth contacting as he has a wealth of knowledge on the older 5 valve Yamaha engines.
feef
Energiser Bunny
PostPosted: 18:01 - 27 Sep 2005    Post subject: Reply with quote
which will also raise the gearing of 1st..
what I really want is to effectovely keep as close to the ratios I have, and gain a 6th higher gear... an "overdrive" if you will.
a
feef
Energiser Bunny
PostPosted: 18:12 - 27 Sep 2005    Post subject: Reply with quote
good find..
cheers..
good read too..
a
stu_m
PostPosted: 23:08 - 27 Sep 2005    Post subject: Reply with quote
silly money
your talking about £300 quid maybe more for a gear
its the time it takes to make then there is the hardening process
craigT19
Jolly Green Giant
PostPosted: 12:43 - 02 Oct 2005    Post subject: Reply with quote
probably easier to buy a new lump mate.
The last post was made 20 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.35 - MySQL Queries: 13 - Page Size: 83.91 Kb
