Kickstart starting problems
Silver
PostPosted: 22:18 - 27 Sep 2005    Post subject: Kickstart starting problems Reply with quote
No, not problems starting Keith, problems starting my Honda XLR250.
I haven't ridden it for a month or so, but got it out of the garage to start it tonight and the bastard doesn't want to know Evil or Very Mad I've now got an aching leg from jumping up and down on the bastard! I can't see I'm doing anything obvious wrong or stupid. There's fuel in the tank, and I've even put it on reserve, just in case. The lights come on when I'm kicking it, and it spluttered a couple of times but didn't catch. Now, as far as I'm aware these don't have batteries (I certainly can't find one) so I'm at a bit of a loss what to try next.
Is jump starting an option (never tried it on a bike Eh? ). Can't see that being anymore effective than me jumping up and down on the kickstart though.
Any ideas welcome...
Thanks!
Korn
Admin
PostPosted: 22:37 - 27 Sep 2005    Post subject: Reply with quote
A few things to check:
1) Is there a spark? Unscrew the plug but leave it connected to the lead and get your girlie to hold it against the motor while you kick it over, it should produce a spark...
2) If there is no spark, have a poke at the ignition (yours has a key, I think?) and kill switch wiring to make sure none of it is causing the trouble. If that's fine suspect the coil.
3) If you get a spark but it still won't catch it might be worth draining the carb to clear out any crap, or stick in on the second level of the choke and kick over for a while holding in the decomp lever, then try normal starting again.
3516 Miles, 11 Countries
finpos
PostPosted: 23:13 - 27 Sep 2005    Post subject: Reply with quote
Either (1) find a nice hill, get on the bike, paddle it down the hill then clutch in, stick it in 2nd and clutch out, or (2) run alongside the bike on a flat surface pushing it 'til you are about to collapse, jump on and do the same. If it doesn't start, either push it back up the hill (1) or pick it off the floor (2). Make sure you had the ignition on/kill off, if you didn't, try again.
If it was ok before it's rest, it will probably start by bumping it. otherwise korn is spot on.
fin.
PostPosted: 02:25 - 28 Sep 2005    Post subject: Reply with quote
If there is no battery, no point in jumping it. Trying for a bump may not hurt except in a muscular way
First check for a spark as described. Make sure it is a good spark and not a shitty jumping to the side of the plug one. It should be fat, blue and jumping directly between the electrodes.
That being all ok, try sticking a few drops of raw petrol down the plug hole then give it a good old swing. Make sure you have it on the sweet-spot before you jump on the fucker.
Nath
PostPosted: 10:56 - 28 Sep 2005    Post subject: Reply with quote
Tried some 'easystart' or similar?
Hard livin', hard luck.
The last post was made 20 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 44.75 Kb
