Security
veeeffarr
PostPosted: 23:05 - 27 Sep 2005    Post subject: Security Reply with quote
Hi,
Currently my bike is in my garden, chained to a drainpipe (Not the most secure thing, I know! Sad )
I can't add ground anchors (Can't do anything that would involve drilling, cutting, moving, cementing etc)
Also I'm quite pissed off I don't have a garage.
It makes me sad to see my bike insecure outside, with no shelter getting rained on, plus it's a real shitter to try and do maintainance in the pitch black in the cold with no space Sad
I'm spending so much money on the bike as well, and the more I spend the more I wonder whether it's a good idea keeping it Sad
Sorry, just really pissed off, I worry all night whether my bike's going to get nicked and I'm pissed off I don't have somewhere warm clean and dry to work on it.
Any ideas?
Toby
Itchy
PostPosted: 23:24 - 27 Sep 2005    Post subject: Reply with quote
reposted concrete block solution from a much older post of mine
cheap and cheerful
The concrete block solution , learned from a mate who used to live in Hong Kong.
Get 2 ground anchors £15 each those that you cement into the ground , buy a couple of those cheapo plastic boxes really big ones used for general storage the cheaper the better as you will destroy them £1.50 each. ,
Now get a mate with a car , and go round to a builders yard or a ready mix concrete place (sometimes they bring it round to you)
and fill the boxes with concrete and put the ground anchors into the drying concrete , and leave it for a day or so hack off the plastic boxes and you have two solid blocks of concrete depending on how big you made them , which you can secure your bike to , if you make some steel reinforced concrete even better... £2 for the concrete £3 for some old steel £10 for a couple pints for an engineering student to build the reinforcement for you
Do not make gigantic cubic metre blocks as you will not be able to move them.
reinforced = better as a bloke with a big hammer can't hit it and crack it easily.
now buy yourself a hand truck , those L shaped things with two wheels that people who move lots of stuff have , and you can bring them into the house when not used and out when you park them £20 , buy one depending on the size and weight of the blocks you want to use.
Since you also have a car its even better make L shaped blocks with simple moulds and park the car over the bits that stick out with the wheels on the concrete slats ,
which serves as an OK hash of a ground anchor which is pretty cheap , however the weakness moved away from a bloke with a van lifting it away into the back of his van to the strength of your chain , but since it is your home immobile security you can use gigantic ship chains to lock it up.
BUT before you even consider this , calculate the weights involved and where you will store the blocks if asked to move them when not in use ,
kawakid
PostPosted: 23:32 - 27 Sep 2005    Post subject: Reply with quote
Sorry to hear that mate.
Is there nothing you can do?
No mates near by with a garage?
No possibility of getting a shed?
Move house?
I've a twin and a 4.
instigator
PostPosted: 23:33 - 27 Sep 2005    Post subject: Re: Security Reply with quote
Finally...your wallet dries up...!!!! Now you can start buying sensibly.
Is there no way you can obtain a hut/shed/metal shed? Anything where the bike is under cover and you can rig some sort of alarm system to. Doesn't necessarily have to be anchored down at all, jsut something where an intruder will be brought to your attention
Walloper
PostPosted: 23:33 - 27 Sep 2005    Post subject: Reply with quote
What if the big blocks fall through the landing of our flats? Laughing
veeeffarr
PostPosted: 23:35 - 27 Sep 2005    Post subject: Re: Security Reply with quote
Haha, I've always been skint! Smile Haven't spent that much money Smile
veeeffarr
PostPosted: 23:36 - 27 Sep 2005    Post subject: Reply with quote
I'm toying with the idea of a shed... Going to have a look soon Smile
Another disheartening thing is that I can barely get my CG through the gate... If I get a bigger bike its not going to go in Sad
tatters
Exxon Valdez
PostPosted: 23:40 - 27 Sep 2005    Post subject: Reply with quote
The concrete block solution and a heavy chain + disk/U lock and maybe a hidden killswitch between the coil and its supply will do to stop joy riders/Chavs, its unlikely professional thief’s would go for a CG125 so theres no need to go OTT.
ZZR Girl
PostPosted: 14:01 - 28 Sep 2005    Post subject: Reply with quote
My bike is garaged, plus steering locked, plus chain & padlock, plus disk locked. Am I being paranoid? Wink
Keep it shiny!
Walloper
PostPosted: 14:03 - 28 Sep 2005    Post subject: Reply with quote
Yeh Laughing
Type_Mo
PostPosted: 14:28 - 28 Sep 2005    Post subject: Reply with quote
BikeTent ?
map
Mr Calendar
PostPosted: 14:30 - 28 Sep 2005    Post subject: Re: Security Reply with quote
Toby R wrote:
...Can't do anything that would involve drilling, cutting, moving, cementing etc...Any ideas?
Are you sure? If putting around a drainpipe at the moment couldn't you drill a bolt (or several) into the wall with a closed loop head to fit the chain through?
Just a thought Thumbs Up
The last post was made 20 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 76.61 Kb
