| gwminor48 |
 gwminor48 L Plate Warrior
| mr.z |
 mr.z World Chat Champion
 Posted: 12:20 - 29 Sep 2005 Post subject: |
Try changeing your air filter and spark plugs, both these could cause crappy idleing, otherwise (this one is more likely but more hassle hence try it second) its the carbs, if its been stood for a while they might need cleaning, take them off and give then a good clean out (idle jets especially).
Good luck (cool bike by the way ) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| map |
 map Mr Calendar
 Posted: 13:02 - 29 Sep 2005 Post subject: |
An idea would be to check/renew your HT leads and plug caps. I'm thinking if it's a problem at low revs (therefore low alternator output) if the leads are breaking down this will cause a problem for the current. At higher revs you get higher current and therefore it can 'jump' over any breaks.
Always a good idea to do a mini service (oil, filters, plugs) on a new to you bike as then you know it's done and can arrange for it to be redone from that date/mileage. Also a good idea to replace leads every 2-3 years (although that may be me being cautious). If you don't know when the last time this was done it might be an idea to include with the service.
Just a few thoughs  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Bezzer |
 Bezzer World Chat Champion
| stinkwheel |
 Posted: 14:36 - 29 Sep 2005 Post subject: Re: 1971 Honda cb750 idles & runs rough up to 3-3,500 rp |
| gwminor48 wrote: | This bike seems to have the electronic type points. |
So does this mean it has points that open and close, or an aftermarket electronic ignition. If it is the latter, your coils, plug leads and battery need to be in tip top condition for it to work right (especially if it is a boyer microdigital).
On standard points, if the timing was a bit too far advanced, it would be a bastard to start and rough at idle. Should be easy enough to check the static timing, you should also see the auto-advance flying out if you rev the bike up whilst looking at it, not that I have ever heard of an auto-advance unit failing.
Also worth checking it is firing on all four at low revs, might be dropping a cylinder or two?
Carb balancing may also be a good idea. Unbalanced carbs can cause a very vibey and uneccessarily high idle speed.
I presume it has the proper airbox? Those bikes are renowned for not liking aftermarket pod filters (which everyone fits when they find they can't get the airbox rubbers back on). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| gwminor48 |
The last post was made 20 years, 273 days ago. Instead of replying here, would creating a new thread be more useful? |
