help needed quickly
on_one
PostPosted: 17:28 - 29 Sep 2005    Post subject: help needed quickly Reply with quote
my aprilia rs50 isnt ticking over at all it runs ok when your going but you have to keep the revs up other wise it dies, it also sounds crap when the revs are picking up its done 8700km
Marci
PostPosted: 18:09 - 29 Sep 2005    Post subject: Reply with quote
Check idle screw and pilot screw settings on side of carb... sounds like it's dropping too low at idle for one reason or another.
Ideally, strip float off carb and check for scum.... rinse it out in unleaded, blow thru jets one by one... check airfilter isn't excessively blocked...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
yambabe
PostPosted: 01:28 - 30 Sep 2005    Post subject: Reply with quote
Is it manual or auto choke?
If it's an auto choke, another possibility is that your choke is stuck on. You could check it and clean it.
(Or I suppose it's possible that you're not taking the choke off once you get it started & warmed up, but I know you're not that daft ..... are you?)
Robby
Dirty Old Man
PostPosted: 01:49 - 30 Sep 2005    Post subject: Reply with quote
Sounds like a flat battery. Charge it up and see if it improves.
on_one
PostPosted: 16:37 - 30 Sep 2005    Post subject: Reply with quote
fixed it the choke on the carb hadcome out slightly in the joint so it was stayingonjust enough for it not to run
The last post was made 20 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 42.98 Kb
