Chain
Dracan
PostPosted: 23:48 - 29 Sep 2005    Post subject: Chain Reply with quote
On a ride out the other weekend, one of the other guys noticed that my chain was making a rattling noise. On closer inspection, one of the links was seized. I've worked some chain lube into the link and it's freed up a bit. I don't know how long it was seized for, and am just wondering whether it's safe to carry on using that chain? Or should I get another one fitted? How much am I talking for a new chain? It's a Triumph TT600 btw.
Cheers,
Dan.
Honda CBR600RR - 2004
Ichy
PostPosted: 00:39 - 30 Sep 2005    Post subject: Reply with quote
Generally most chains are now sealed so chain lube only tends to clean the outer surfaces and stops grit getting inside. If it a rivetted chain and its towards the top end of adjustment then you could take the link out Question
I would probably change it unless it was fairly new, although I'm not sure what problems it might cause, if any.
bish777
PostPosted: 02:48 - 30 Sep 2005    Post subject: Reply with quote
if the chain is worn but the sprockets are ok, slap a cheap non oring chain on for now then change the whole lot for flashy x ring at a later date.
heavy duty non oring chain will set you back 25 quid or so.
GSXR1100J
The last post was made 20 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.64 - MySQL Queries: 13 - Page Size: 35.4 Kb
