Sump Bolt!
Vin
PostPosted: 13:03 - 30 Sep 2005    Post subject: Sump Bolt! Reply with quote
I am trying to change the transmission oil on My TZR250 (I wish I hadn't bothered!!) It has two drain bolts both of which I removed and drained the oil. I replaced one no problem but when I replaced the second it refused to tighten properly. When I removed the bolt I noticed it had been stretched to the point of breaking. The case thread looked OK. So I got another bolt (not easy) and washers and set the torque wrench to 10ft/lbs (below the yamaha recommended level) and started to wind the bolt in and bugger me if the same thing didn't happen again. I find this a bit weird does theis mean the case thread is damaged? I can't quite believe how easy it is to ruin the bolt!!
Any thoughts?
Vin
PostPosted: 13:36 - 30 Sep 2005    Post subject: Reply with quote
Is the bolt you are trying to put in the correct thread pitch?
Sump plugs are usually a fine-pitch metric thread, which is a pretty specialised size. You might be trying to screw a standard-pitch bolt into a fine pitch hole.
If the thread in the casting is damaged, you would need to find out what the correct size thread for it is then run a greased tap along it to clean it up.
If you can't find a tap, a bolt of the right pitch with a groove dremmeled along its length to just deeper than the thread can be used to 'tidy up' a slightly bent/raggedy thread. Screw it in like you would a tap (ie half turn in, quarter turn out, half in, quarter out).
Korn
Admin
PostPosted: 14:29 - 30 Sep 2005    Post subject: Reply with quote
If you've bollocksed the thread that the sump plug screws into, it's going to need a helicoil or other type of thread repair.
For a short term bodge you can drill a hole through the head of the bolt, screw it in just past hand tight using liberal amounts of instant gasket and lockwire it to something that won't allow it to budge.
3516 Miles, 11 Countries
Vin
PostPosted: 15:28 - 30 Sep 2005    Post subject: Reply with quote
I'm pretty sure its the right bolt. The original had always been there and the second was sent to me by Taymar Racing who should know. I guess what ever way I look at it the case thread must be buggered I just can't understand why it knackers the bolt though! Weird.
Anyone want to buy a TZR :-/
sickpup
Old Timer
PostPosted: 00:39 - 01 Oct 2005    Post subject: Re: Sump Bolt! Reply with quote
Don't really understand this as it would take several tonnes to stretch a steel bolt.
Pretty sure it's a 12mm on a TZR so just re-tap it out 14mm as these are the two common sump sizes. New sump bolt should cost about £6.95
alains
PostPosted: 00:52 - 01 Oct 2005    Post subject: Reply with quote
i know this problem . you should have clean the thread before trying to refit the bolts . the dust metal exiting has stocked in the thread and then you cannot screw it properly , especially if your bolt is long . what i have done to solve the trick is :
- i've taken a tap at the right size and solder on line an extention at 1mm under diameter size
- solder an other piece in "T" at the end
- then turn the tool inside gently until the thread was clean and the bolt went in easily
cost : a tap and a bit of steel soldering (electric ark) 4 quids may be
PostPosted: 16:26 - 01 Oct 2005    Post subject: Reply with quote
It isn't a sump bolt in the normal sense... its just a drain plug. This is because the bike doesn't have a sump!
Not heard of bolts stretching or whatever, but I changed the transmission oil on my TZR last week and could only find one drain plug on the right hand side of the bike at the bottom.
I realised that the oil would pool on the left hand side of the bike so I leant the bike over the opposite direction and held it up above my catch container like that until no more oil came out.
The bike is so light that this wasn't an issue. Maybe I should look at the other drain plug though... Smile
alains
PostPosted: 17:12 - 01 Oct 2005    Post subject: Reply with quote
on mine (nsr) one bolt is use as a drain , but when the old oil goes out it brings dust metal into the thread , that's what i was thinking on your's and why i made this special tap .
Vin
PostPosted: 18:35 - 01 Oct 2005    Post subject: Re: Sump Bolt! Reply with quote
Tell me about it. Maybe it isn't stretching. Looking again its like the bolt is getting cut through. I haven't got a camera to take a pic unfortunately.
Thanks for all the advice I will try cleaning up the thread. I bet I bollox it. I will order a proper yamaha replacement bolt.
To clear up the drain bolt issue. The TZR has two drain bolts on the right hand side of the gear box in the side case. The manual recommends both are removed to drain the oil. Its the front smaller one that is giving me the hassle.
See attached page of manual.
simon1221
PostPosted: 17:34 - 02 Oct 2005    Post subject: Reply with quote
Dont use the torque wrench on the sump bolt, theres no point.
Bomberman
PostPosted: 17:44 - 02 Oct 2005    Post subject: Reply with quote
Shocked That's an awful piece of advice mate. Unless you have wrists like a babies, I'd definately use a torque on that.
Vin
PostPosted: 14:30 - 03 Oct 2005    Post subject: Reply with quote
Bomberman wrote:
Shocked That's an awful piece of advice mate. Unless you have wrists like a babies, I'd definitely use a torque on that.
Especially as this is just a drain bolt of very measly proportions.
The last post was made 21 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 75.17 Kb
