Rear wheel bearings
Slinn84
PostPosted: 20:49 - 01 Oct 2005    Post subject: Rear wheel bearings Reply with quote
Just changed the tyre on my rear wheel and thought that since the wheel is off i'll give everything a damn good cleaning and check its all in order
took the sprocket cush and damper drive off and the disc off to check the rotation of the bearings and noticed that the inner part of the bearing is very stiff on both sides of the wheel
the metal outer fits tightly into the wheel so no probs there, the middle seals are fine, but the inner metal ring thats supposed to spin with your axle is very stiff, it does turn but not very easily
is this a real problem?? how can i fix this??
any help welcome
cheers
Slinn84
PostPosted: 20:49 - 01 Oct 2005    Post subject: Reply with quote
Yamaha Thundercat btw Razz
Guest
PostPosted: 21:01 - 01 Oct 2005    Post subject: Reply with quote
New bearings needed by the sound of it - I assume they were bone dry?
Easy job, bearings for less than a tenner from a bearing factor, £20+ from a bike shop Mad
PostPosted: 21:02 - 01 Oct 2005    Post subject: Reply with quote
They are a bit stiff, the bearing is full of grease which will be fairly solid when cool. Put the wheel back in but leave the calliper off and the bike up on the stand. Now give it a spin. It should spin freely between the forks and there should be no 'grumbling' or grinding noises coming from the bearings (listen carefully). There should be no play from side to side when you wiggle the wheel.
You can usually "feel" any roughness in the bearings as you turn the wheel by hand.
Slinn84
PostPosted: 17:35 - 02 Oct 2005    Post subject: Reply with quote
rear wheel so it dunt fit between forks Razz
the bearing spins round freely, no notches or sticky points, its just very stiff, with the wheel on i can give it a good spin and all i can hear is the pads brushing against the disc, theres no wiggle from side to side or anything
i've only just got the bike back on the road after my old rear tyre got a puncture, so i dont fancy having it set up in my garage again waiting for new bearings to come
cheers guys
The last post was made 20 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 43.47 Kb
