| bsquiggle |
 bsquiggle Derestricted Danger
| instigator |
 instigator Super Spammer
 Posted: 00:04 - 30 Sep 2005 Post subject: |
Yes, you can ride to a pre-booked appointment for an MOT or either to get work done FOR an mot.
I left a week between mine failing and then booking it in (same garage)...He was a little mystified at how I had done about 400 miles if I just took the bike straight home like I said I did.  |
| bsquiggle |
| instigator |
 Posted: 00:09 - 30 Sep 2005 Post subject: |
If it's current then surely, yes. I say surely becasue I#'m not 100% sure but all in all, you do have a valid MOT, and if it hasn't expired I don't see how there can be a problem with that.
https://www.ukmot.com/bike/1-4.asp
Not sure if that link helps, everyone just seems to post it.  |
| Ichy |
 Ichy World Chat Champion
 Posted: 00:13 - 30 Sep 2005 Post subject: |
Absolutely no problem, in fact I think that if the MOT has at least a month on it then the new one can run for thirteen months.
Actually, thats assuming that there is nothing illegally dangerous on the bike, in which case they can refuse to allow you to ride it away. (might of just made that up ) |
| bsquiggle |
 Posted: 00:17 - 30 Sep 2005 Post subject: |
thanks - can i print this thread out to carry with me in case of trouble?  |
| david916 |
 david916 Renault 5 Driver
 Posted: 00:48 - 30 Sep 2005 Post subject: |
An MOT is basically a yearly 'safety' check and although it remains valid for a year after the test is carried out it only really lets you know that the bike or car is ok after the test has been carried out on the actual day. Things can change a lot over the following year. The tyres, brakes and loads of other things all wear out. You should still maintain the vehicle in a legal and roadworthy condition during that time. When you take the vehicle in for a new MOT and it fails then it means there is something wrong with it and that MOT test (failure) then supercedes the previous MOT. Normally you would give the garage the old MOT so that the new one runs for a full year from the expiry date of the old one, but if you don't give them the old one and it is still in your possession then the vehicle should not really be driven/ridden as it is now deemed unroadworthy and illegal. If the police found out the vehicle had failed an MOT you could be reported for using a vehicle without a valid MOT (they would need to prove you knew it had since failed) and they would also report you for offences with regard to the defects the vehicle failed on if you were driving/riding on a road! If your vehicle was involved in a serious or fatal accident the vehicle would almost certainly be examined by the police and the faults would then come to light. You might end up being prosecuted for causing death by dangerous driving/riding (condition) if it was a contributory factor in the collision. There is an anomoly in the law however, that you can take a vehicle with no MOT, or one that has previously failed an MOT, to a garage for a test provided there is a pre-booked appointment. If you got stopped the police would probably check with the garage you stated you had made an appointment at to make sure you were telling the truth. They would not be pleased if they found out you were 'fibbing' and you would suddenly feel books being thrown at you!
It's not worth it. If it fails then it's dangerous so get it fixed and re-MOT'd asap or scrap it if it's not worth repairing. Don't risk driving/riding without a valid MOT.
Hope this helps.
https://www.ridesafe.org.uk ____________________ Currently own/regularly ride :
Suzuki SV1000S K4
| david916 |
 Posted: 00:56 - 30 Sep 2005 Post subject: |
Also, you're allowed the journey to/from home (or wherever the vehicle is normally kept within reason) and the MOT testing station. If the faults on the vehicle are found to be serious then the tester will advise you about driving/riding the vehicle home and point out the consequences. If you were subsequently involved in an accident then the tester might be called as a witness against you in court!
Suzuki SV1000S K4 |
| bsquiggle |
| Walloper |
 Walloper Super Spammer
| Ichy |
 Posted: 20:52 - 01 Oct 2005 Post subject: |
Just found this on https://www.motester.co.uk/qanda2.html
MOT CERTIFICATE VALID UNTIL FAILURE DATE
A friend of mine maintains that if you have a car MOT Tested before the expiry date she will have 2 weeks in which to repair / drive it before it is illegal. I am under the understanding that once the MOT has expired you are not permitted to drive at all unless going to and from a place of repair (MOT Garage or otherwise). Please can you clairfy the correct and legal thing to do. Many Thanks, Dan Clark
Your MOT is valid until its expiry date even if in the meantime your
car fails the MOT - the original pass is still valid. In fact you can have the Test done up to a calendar month before the expiry date and have the new MOT forward-dated to the expiry date of the existing certificate. So if you have your car Tested during that month and it fails, this gives you time to have the repairs carried out and the car re-tested before the expiry of the original certificate and you are not disadvantaged as a result. - MOTT. |
| instigator |
 Posted: 23:37 - 01 Oct 2005 Post subject: |
Since this topic is now answered, could I butt in and ask away so to save on more bumff floating about on this forum?
I'll take that as a 'yes', thanks.
On the hornet, I had fitted some flush mounted indicators to get around the silly high level exhaust clashing problem. They are clear lenses, instead of orange ones. (I asked for orange, but I needed them so didn't ask for a refund) What I'll do if they do need to be replaced is beyond me as I don't have any space/any connections to the numberplate bracket to hold normal indicators on.
Do I need orange one's on the bike to pass it's MOT?
Also, how do you go about rigging in one of these LED number palte lights? The hornet AND sv need one becasue they have stupid replacement undertrays. On the wiring loom, you have the usual, back brake connection, indicator connections and I presume another for the back brake light. Where would you connect the LED connections?
Why people bother with such stupid accessories is beyond me if you have to change all this pish about every year.  |
| Ichy |
| instigator |
 Posted: 23:57 - 01 Oct 2005 Post subject: |
Top man, cheers.
I understand the indicators have to be spaced by a minimum of 23cm?
Hmm... Not sure how that affects flush mounted indicators. |
| Ichy |
 Posted: 00:52 - 02 Oct 2005 Post subject: |
Drilling a small hole in the bottom of the tail light lens should be sufficient to give the required "downward white light" onto the number plate. It is good enough for enduro bikes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 20 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
