Carbon fibre reeds for NS125, Will it benefit me????
brown_d9
PostPosted: 12:26 - 02 Oct 2005    Post subject: Carbon fibre reeds for NS125, Will it benefit me???? Reply with quote
I have an 1988 NS125F with a micron exhaust system and am interested in some carbon fibre reeds, will it make much difference, iv heard its not so much a performance mod but will make it smoother throuhgout the rev range
Is this true?
Can someone point me in the right direction as i cant find them anywhere?
Thanks alot
PostPosted: 14:28 - 02 Oct 2005    Post subject: Reply with quote
Next to no difference. On some older bikes they fitted steel reeds and against those there would be an improvement, plus they would be a bit less likely to damage the engine when they failed.
On an NS you will get far more difference by playing with the airbox.
alains
PostPosted: 15:30 - 02 Oct 2005    Post subject: Reply with quote
not a lot , but surely will improve the smoothness of the bike due to a better filling of the barrel . it's not necessary to spend more than £25 for that .
brown_d9
PostPosted: 18:05 - 02 Oct 2005    Post subject: Reply with quote
What can i do to the airbox then?
alains
PostPosted: 18:07 - 02 Oct 2005    Post subject: Reply with quote
nothing , just clean and slightly oil the foam
PostPosted: 18:08 - 02 Oct 2005    Post subject: Reply with quote
Dump it and replace with a single filter, and rejet to suit. Or failing that drill holes in the airbox (such that you just allow more air to the outer side of the air filter) and again rejet.
Marci
PostPosted: 18:08 - 03 Oct 2005    Post subject: Reply with quote
I've found since popping the airbox off and replacing with K&N Filter, mainjet had to be upped to 125, and pilot jet had to go up 2 sizes too... Power jet was fine as it was... might not be same for you, but worth bearing in mind... (mine's an 89 NS125R)
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
alains
PostPosted: 18:40 - 03 Oct 2005    Post subject: Reply with quote
i do not recommand to fit a K & N filter , because with the rain , you will get trouble
PostPosted: 19:07 - 03 Oct 2005    Post subject: Reply with quote
Not sure on the NS but never had problems in the rain with one on my MBX125.
Only time it was a problem was if you jet washed the bike Embarassed .
brown_d9
PostPosted: 22:52 - 03 Oct 2005    Post subject: Reply with quote
I have already upjetted the main jet to a 120 becuase of the exhaust, and have drilled a few holes in the airbox, the plug colour is good and there is no bogging down under full throttle which im quite pleased about. The midrange though is very lumpy, is there anything i can do to smooth this area out???
Thanks so far
Dan
alains
PostPosted: 23:11 - 03 Oct 2005    Post subject: Reply with quote
may be adjusting the valve
brown_d9
PostPosted: 23:17 - 03 Oct 2005    Post subject: Reply with quote
What valve?
alains
PostPosted: 23:20 - 03 Oct 2005    Post subject: Reply with quote
the exhaust valve , you've got a TC01 hav'nt you ?
it's a mechanical one , it can be adjust i think
brown_d9
PostPosted: 23:26 - 03 Oct 2005    Post subject: Reply with quote
Just a bolt in the side of the barell, no power valve unfortunately.
alains
PostPosted: 23:41 - 03 Oct 2005    Post subject: Reply with quote
i am not thinking about a power valve , but the exhaust chamber has a valve inside which moves mechanically ?
brown_d9
PostPosted: 08:07 - 04 Oct 2005    Post subject: Reply with quote
Nope, the NS125F dosnt have this fascility, just a blanking plug, maybe your thinking of the NSR?
Marci
PostPosted: 11:16 - 04 Oct 2005    Post subject: Reply with quote
UK NS125's don't have the ATAC chamber which is the valve system to which you're referring alains... UK restricted bikes had this system removed and the exit port blocked by a blanking plate on the end of the big bolt mentioned above. Lop the end of this bolt for top end performance, but you sacrifice a LOT of off-the-line pull. If you want to keep some low end pull, leave the bolt alone.
Also, no probs here with k&n on my NS125R in the rain.... got thoroughly drenched several times last week and bike didn't twitch a whisker...
alains
PostPosted: 11:30 - 04 Oct 2005    Post subject: Reply with quote
thanks , mate . even older people learn every day Very Happy
PostPosted: 11:42 - 04 Oct 2005    Post subject: Reply with quote
This chamber is open for the low revs position on the full power bikes. Opening it up more will not add to the top end power. To get the effect you are thinking of you would lengthen the bolt to block the chamber off.
Marci
PostPosted: 13:04 - 04 Oct 2005    Post subject: Reply with quote
Yep, my mistake.... mis-recalling an earlier convo with ya elsewhere on the site Embarassed
brown_d9
PostPosted: 17:03 - 04 Oct 2005    Post subject: Reply with quote
Is there any way i can fit a powervalve to my bike, what things would i need, is it mechanically operated or electronically?
PostPosted: 12:48 - 05 Oct 2005    Post subject: Reply with quote
They are mechanically operated. Should be possible to fit all the parts but I doubt it would be cheap to buy them new.
There used to be a gas pressure operated power valve system that you could buy that you welded to the exhaust. Not seen them advertised for about 15 years.
The last post was made 20 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 114.39 Kb
