| byke95 |
 byke95 World Chat Champion
 Posted: 10:02 - 03 Oct 2005 Post subject: Supermoto: sticky accelerator, stiff clutch and kick-start |
Hi!
Picked up my XR600R on Saturday and I'm pretty chuffed with what I've got. However, I need help with three problems please:
1) It's got a very sticky accelerator; it doesn't rotate smoothly at all meaning any kind of throttle control is impossible. How do I fix this?
2) You need a grip like Mike Tyson to change gear, the clutch is so stiff; by the time I'd rode it home my hand was killing me! Is there an easy way of loosing this up?
3) Ah, the kick-start. I know there is an art to learn from this and I will get it, eventually. Thing is, the guy I bought it off didn't offer me much advice, at the moment it's taking me 20 mins to get it started. I'm not sure about this piston/ignition start thing and how the compressor lever above the clutch lever helps?
Thanks for the help!
Phil |
| finpos |
 finpos World Chat Champion
| byke95 |
 Posted: 13:54 - 03 Oct 2005 Post subject: |
Cables could also just want oiling?
Wear big solid boots for kick starting a thing like that. You might need more than one press of the kickstart to bring it up to compression. You will eventually learn where the 'sweet spot' is for this (some bikes used to have a window into the crankcase you could line up a mark in, XT500 for example).
Once you are at the 'sweet spot', let the kick start return to the top. You now need to give it some welly, really swing that engine over, don't be half-arsed about it or the bike will kick back and it will hurt (hence the boots). A single big kick with a lot of weight pressing down on the kickstart and swinging it through its full arc, if you watch 'old hands' at it, you will see both feet are off the ground, this takes a certain amount of balance.
If it doesn't fire up, start again.
You really want to be sat astride the bike for this, I see people trying to start big singles while stood next to them and it doesn't work. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| finpos |
| G |
 G The Voice of Reason
| byke95 |
| G |
| byke95 |
| cagiva gezzer |
The last post was made 21 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
